It is currently Mon Aug 04, 2025 12:50 am
 Post subject: Neck joint video on Lmi
PostPosted: Fri Oct 09, 2009 7:55 pm
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
:mrgreen: I was watching the neck joint video on LMI's website and was kind of surprised how it was done he cut the mortrise after the body was made he also cuts a tenon that is not at a 90 degree angle to speed setting the neck. Is there in advantage in doing this in this order? I still am having trouble understanding how he arrives at the proper angle for the tenon. Has anyone had any experience with is method. Thanks Bill the Greenman
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Fri Oct 09, 2009 9:06 pm
First name: Tom
Last Name: West
State: Nova Scotia
Greenman : You don't need all those jigs to do the mortise and tenon.I do both of them on the table saw and they can be done with hand tools if need be.Because of the requirements for playability you have to build about a 1.5 degree back angle at the neck connection to make things work out ok. Suggest you get a good reference book and read it thoroughly and understand all the concepts before undertaking your project.When I first started to built one of the things I caught on to real fast was the need to know the consequences of every step you completed ie how did it effect the next step and any additional steps.In other words always try to think ahead.Good luck with your project.
PostPosted: Sun Oct 11, 2009 11:20 pm
Bill,
You can do it by hand as was suggested. The jig comes in handy in a production/classroom enviornment and increases accuracy and precision. However, if you don't have a dog then hunt with a cat.
Happy Building!
