It is currently Sun Aug 03, 2025 3:09 pm
PostPosted: Sun Oct 04, 2009 12:25 pm
Hi! I'm getting close to applying finish on my first. I am using an ebony headplate. Do I need to grain fill the ebony in order to get a flat, smooth finish?
PostPosted: Sun Oct 04, 2009 12:39 pm
First name: jack
No Mike, ebony is close-grained, and as such does not require pore filling,
regards,
jack
PostPosted: Sun Oct 04, 2009 12:55 pm
well, for me it depends on the piece as to whether the pores are close or not ... I simply use the gel CA on all of them .... takes about 3 minutes to get it prepped, and you are golden.
PostPosted: Sun Oct 04, 2009 4:33 pm
My thanks to both of you. I thought that I had heard or read that there was a general consensus that it was closed grain, but thought it might be prudent to ask before I began finishing. Thanks again!
PostPosted: Mon Oct 05, 2009 1:04 pm
First name: Matthew
Last Name: Rust
City: Columbus
Zip/Postal Code: 47201
Another thing to consider is the finish you are using. My first was Tru-Oil and the pores are very apparent, even after 8 coats and using the sealer/filler. My second is lacquer with a couple seal coats of shellac underneath and it is mirror smooth.
Don't confront me with my failures--I have not forgotten them.
PostPosted: Mon Oct 05, 2009 2:31 pm
Thanks, Matthew. Finish will be lacquer.
Users browsing this forum: mikeyb2 and 34 guests
