It is currently Tue Jul 29, 2025 10:39 am
PostPosted: Thu May 28, 2009 10:49 am
First name: George
Last Name: Thomas
Hi:
I have been following an interesting thread on another forum (not a member due to infrequent posts) and wanted to see what folks here thought about a related question. For classical guitars would you reduce the size of the plantilla if planning on using a 630mm scale length? The other thread had to do with slightly smaller guitars and got into a discussion of hand size and the optimal scale for smaller hands.
There was another discussion of hand size and measuring it a while back and referenced an author named Alicia, last name forgotten. I have not been able to find in the archives here or on the other forum. Does anyone remember this? Thanks.
GEO
perpetual beginner
PostPosted: Thu May 28, 2009 12:03 pm
George I'm in the process of building my second guitar with 24.9 scale. I find that with my small hands its much easier to play. In both cases the mods were minimal - shorter neck and I just moved up the bridge a bit. On the steel string the X bracing was such that moving the bridge closer to the sound hole had minimal impact. On the CG no mods required to fan bracing.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu May 28, 2009 2:36 pm
That prior thread about hand size probably reffered to Alicia Kopfstein-Penk, who wrote a book called 'The Healthy Guitar' about this subject. You can get the book from her:
c.kopfstein@verizon.net
PostPosted: Thu May 28, 2009 6:33 pm
First name: George
Last Name: Thomas
Alan:
Thanks for the email address. I will give a try. By having her full name I was also able to find another email address for her (akp@american.edu).
Ricardo:
There does not seem to be any structural reason to move up the bridge and make the necessary bracing adjustments to accomodate a shorter scale. There might be an aesthetic one. We will see when I give it a try. Thanks.
GEO
perpetual beginner
Users browsing this forum: Chris Ensor, pullshocks and 14 guests
