It is currently Mon Jul 28, 2025 9:12 am
 Post subject: Shoulder reinforcement
PostPosted: Tue May 05, 2009 6:53 pm
I am attempting a guitar with an entirely bolt-on neck. My natural concern with this is the loss of that oh-so important glue joint between the fingerboard tongue and the face of the guitar. It seems to me like the shoulders would be much more free to move around, and that the top would be more likely to cave in above the soundhole.
I have noticed that some builders are using a Carbon-Graphite "Flying Buttress" to combat this problem (this was originally Rick Turner's idea?), and I was wondering is anyone has any experience with this? My main concern is the distribution of the pressure into the waist, which would still deform the top and back, just in a different way.
I have also noticed that many instruments dating back over a century have used a long bar that runs from the head block to the end block, which I assume is to address the same issue.
Is one method more effective than the other, or has this Flying Buttress system even been around long enough to judge?
Thanks in advance for your opinions!
If you don't have to reach over your head to turn the knobs, your amp is too small.
PostPosted: Wed May 06, 2009 5:02 am
Here's a link to a couple of the threads detailing the way I do it with a bolt on neck. There are other threads which also detail it. This is a very stable system which I have been doing for years with no problems.
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=19290&p=271512&hilit=neck+extension#p271512
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=19044&hilit=redwood
PostPosted: Wed May 06, 2009 6:33 am
That's a well thought-out approach, thanks for sharing! I especially like how much reinforcement the tongue gets, most bolt-on systems don't address that.
PostPosted: Wed May 06, 2009 6:46 am
Larry also check out Dave White's CF butresses, just search using butresses and put Dave White in the second box.
PostPosted: Wed May 06, 2009 12:34 pm
A bit off-topic, but how are you doing these days, Colin?
Users browsing this forum: Bing [Bot] and 15 guests
