It is currently Mon Jul 28, 2025 6:40 am
PostPosted: Fri Apr 03, 2009 4:01 pm
Last Name: Kitchen
State: SW Pa
I got the Stew Mac frame. How do I tighten the blade!?
I stopped by a hobby shop and they can get magnifier eye cover thingys. Sorry to get so tech :) They come in various distance from subjects from 4" to 20" away. Also, they have a few different magnifications. Should I wait for ASIA to by Magnifier eye cover thingys or do any of "our" dealers handle what I need?
PostPosted: Fri Apr 03, 2009 4:15 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
If the saw frame is like what I use, I tighten the clamp on one end of the blade and the flax the frame ends closer together and tighten the other end while holding the flex. The tension holds the blade tight. Stew Mac wanted too much for their saw frame and I bought a cheap one that works well.
Fred
Fred Tellier
PostPosted: Fri Apr 03, 2009 4:18 pm
I assume you are speaking of inlay saw. There are thumb screws at both ends of the "C". Loosen the top one while maintaining the lower one. Now flex the "C" in just a tad and tighten the screw. The "C will flex back and this will tighten the blade. you don't want it overly tensioned as these blades are easly snapped.
OtiVisor are a good set. Stewmack carries them as well. I have a pair of Bausch & Lomb with interchangable lenses I find more comfortable than the OpiVisor
PostPosted: Fri Apr 03, 2009 6:07 pm
Last Name: Kitchen
State: SW Pa
Optivisor? I like my name better :) Thanks for the info!
PostPosted: Fri Apr 03, 2009 8:34 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
IMHO the inlay saw Stew mac sells is lacking. I'd recommend one that the length of the frame is adjustable. The blades break pretty easy. If it breaks near the end you can just adjust the frame and keep using the same blade.
http://www.widgetsupply.com/page/WS/CTGY/jeweler-saw
PostPosted: Sun Apr 05, 2009 4:18 pm
You can also just get some cheap reading glasses at the local drug store . RioGrande for saws and blades. And don't breath the dust in. You should have a respirator or a vacuum with a HEPA (sp?)filter.
