It is currently Wed Jul 30, 2025 1:27 am
PostPosted: Thu Apr 02, 2009 4:21 pm
Last Name: Hodge
Has anyone here ever used Alaskan Yellow Cedar for Bracing and or Linings? Or do you know of someone
who has with good results? Just curious because I have a bunch of it and I'm considering some for necks
and the rest for bracing and lining stock if that's a feasible option.
I'd like to thank everyone who will for their input in advance. Gotta head back out to the "man cave" :D
Bill Hodge
PostPosted: Fri Apr 03, 2009 12:31 pm
Last Name: Hodge
Bump Eat Drink
Bill Hodge
PostPosted: Fri Apr 03, 2009 1:10 pm
Would work ok for linings but I wuld think it may be too subject to movement for necks, Spanish Cedar a better choice for necks
PostPosted: Fri Apr 03, 2009 1:54 pm
Last Name: Hodge
Thanks Michael. As always, I appreciate your wisdom on this. :D
I posted this yesterday and was beginning to think maybe I had bad breathe or something. :mrgreen:
Bill Hodge
PostPosted: Fri Apr 03, 2009 2:30 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got a 000-12 fret out there that's a little over a year old with a Yellow Cedar neck. It's a 3 piece neck with 1/4" Mahogany in the middle. It's alot lighter than Spanish Cedar. I'm sure it would make great linings. IMHO it's stiff enough for bracing, but is it a little heavy?
PostPosted: Fri Apr 03, 2009 2:54 pm
Now a laminated neck would likely be fine
PostPosted: Fri Apr 03, 2009 4:24 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I built a classical guitar several years ago using all yellow cedar, including the neck. I put a double acting truss rod in the neck & it has not been a problem. I haven't needed to adjust the rod yet. YC is famous for its stability. (Once it has been properly dried)
Yellow cedar is very soft & dents easily, so expect to get "bruises" over time.
I would not use it for braces, based on a friend's experience of building his "worst ever sounding guitar". He blamed it wholly on the YC bracing. (Grain 'O' salt)
I do use it for kerfed linings, & intend on using it on my next project which will have laminated, solid linings.
Careful with the dust... One can quickly become sensitive or allergic to the stuff.
