Chris Paulick wrote:
Well I was going to use a frisket film and some auto pin striping tape. I now have painters tape masking the bridge and have 2 sessons of blonde on the top. I don't want the amber to go over the shell as it makes the nice blues look green which I'm not keen on. I was thinking of top coating with nitro for protection and using the FP as a thin layer of shellac. If I go that route then I guess I'll just leave the masking on until the FP is done and the nitro should level out the difference. What do you think?
I probably should have just stained the top and went with all blonde. I suppose I could sand back the 2 sessions and stain.
Personally I agree that if you wanted the top wood to be a different color then you would have been better off to stain the top before FP started. I think if your are going to cover this with nitro I would stop where your are and consider that your sealer and just spray nitro form here out. Or you could spray shellac for that matter. But you will not end up with a French polished top because too much of the process will need t be circumvented.
If you do decide to cover this in nitro then I see no need the FP over it because the top will sound like a heavy nitro finish. Better off just to add the color to and finish the top off with nitro. Then the masking and such is no issue.
