It is currently Sun Jul 27, 2025 2:29 pm
PostPosted: Sun Mar 15, 2009 5:32 am
First name: Ken
Last Name: Eckerty
City: niceville
State: fl
Zip/Postal Code: 32578
Country: u.s.a.
Hi all,
I am not a builder but I need some luthier advice.
Would there be a problem buying a standard 12 string guitar and then taking off the low end octave strings (E,A,D) and playing it as a 9 string? I'd like to do this without re-slotting the nut. Also, would leaving the 3 tuners without strings, would I get buzzing or rattling from them?
Any advice would be appreciated.
Thanks.
PostPosted: Sun Mar 15, 2009 5:50 am
You'd probably need to re-slot the nut unless you are happy with relatively light gauge E, A and D strings.
If the tuners rattle, Blutac is your friend.
Bob Connor
Geelong, Australia
PostPosted: Sun Mar 15, 2009 5:58 am
First name: Ken
Last Name: Eckerty
City: niceville
State: fl
Country: u.s.a.
Bob,
what is bluetac?
PostPosted: Sun Mar 15, 2009 6:05 am
It's that stuff that you stick posters to the wall with.
I'm not sure what you call it in the States.
It's similar to plasticine but I'm pretty sure you guys have a different name for that too.
Hopefully someone will be along soon with a translation.
This is what wikipedia says it is.
http://en.wikipedia.org/wiki/Blu-tack
Bob Connor
Geelong, Australia
PostPosted: Sun Mar 15, 2009 12:07 pm
First name: Olivier
Last Name: Gauthier
City: Montreal
State: Quebec
if the tuners rattle.... take them off ;) That's what I did with mine... it's ugly, but at least you don't get confused on wich tuner to go for with your strings haha [headinwall]
Other than that, I don't think there would be any problem as long as you're not going for a great tone... If you take out the bottom octaves, your going to get a lot less tension therefore less volume and definition I believe (I'm no pro with all these facts, but that's what I understood.... :geek: ) as for the nut slots... it might feel weird with the string spacing, but there is no problem with leaving it as is. You WILL have to get a proper setup for the instrument afterwards though, to adjust neck relief and maybe more... but that's easy to do if you read about it! plenty of information available here and alsewhere on the net for that.
hope it helps!
Olivier Gauthier
Montreal, QC
PostPosted: Sun Mar 15, 2009 4:16 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Some of the old blues players played 12 strings with only 6 strings, they wanted a wider neck than what was available at that time. Josh White's Guild was custom built for him with a 12 string neck, he had huge hands. One of the past board members of Michigan Fingerstyle Guitar society has that guitar.
Fred
Fred Tellier
PostPosted: Mon Mar 16, 2009 2:39 pm
One the spacing will fill some what awkward. You will have a nut width about 5/32” wider than needed but yes you can do it. I would recommend having a new nut made so spacing intervals were consistent between the center of single course strings and center of the spacing of the double course strings
Users browsing this forum: Michaeldc and 10 guests
