It is currently Wed Jul 23, 2025 12:52 am
PostPosted: Tue Feb 17, 2009 3:01 pm
This was born out of another thread I've got going on, but I wondering who radiuses their bridge plates and why. I guess it never struck me as something I should do, figuring the thin bridge plate would conform just fine to the dome of the top. I'm curious to hear from others about this, though.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Tue Feb 17, 2009 3:16 pm
Well if you don't the in the area around the bridge plate the dome is deformed to near flat. I am not saying at all that is a structurally bad thing. However It does make fitting your bridge to your top more forced fit, because you do not have the continuous dome shape. But in stead you have a flat between the X braces and dome outside them. This means that you bridge bottom can't be radiused to a continuous radius but rather needs to be left flat and the wings are stress down into contact with the top.
This fact is the sole reason I radius my bridge plates prior to installing them.
PostPosted: Tue Feb 17, 2009 3:29 pm
The bridge plate will conform to a curve, but obviously the final curve of the top in that area will be a compromise. We radius everything else so why not radius your bridge plate? It only takes a couple of dozen swipes in the radius dish.
PostPosted: Tue Feb 17, 2009 4:10 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I bend mine like sides on a hot iron.
it's easy to fit & I can alter the bend if I'm doing some experiments.
Plus I know I have a real good glue joint this way !
Sanding can make that small a piece have a less than perfect glue joint !
Mike Collins
PostPosted: Tue Feb 17, 2009 5:31 pm
Bridge plate not the bridge right :D
PostPosted: Tue Feb 17, 2009 8:55 pm
Hmmm...I'll file this in my memory bank. Guess I've been doing it wrong the whole time! Thanks!
Wes McMillian
Santo, TX
PostPosted: Wed Feb 18, 2009 11:32 am
Thanks for calling attention to that issue, Todd. I'll make it a point to chamfer the free edges of my bridge plates more aggressively (my laminated bridge plates are also thinner than the average solid ones, and make a wider footprint north and south of the bridge).
Todd Rose
Ithaca, NY
