It is currently Mon Jul 21, 2025 11:49 am
PostPosted: Fri Nov 28, 2008 11:45 am
I'm looking for jigs for carving necks. I would like to build some that would speed up the process and make them pretty consistant. I know about the tutorials here and the Doolin jig. Anyone have some others that would give me some ideas? I don't care if is for a router or sander or whatever. I'm looking for ideas.
PostPosted: Fri Nov 28, 2008 12:06 pm
Chris,
Here's something I've had in mind for that very purpose and reason. [:http://www.copycarver.com/index.htm [:Y:]
DES - Farwell, MI
PostPosted: Fri Nov 28, 2008 12:07 pm
John Mayes uses a custom made router bit try pm'ing him
Formerly JJH
PostPosted: Fri Nov 28, 2008 12:22 pm
Chas Freeborn uses a 1 1/8" radius roundover bit.
PostPosted: Fri Nov 28, 2008 12:30 pm
Anybody got a link to any pics of the Doolin setup?
-jack handy
PostPosted: Fri Nov 28, 2008 12:41 pm
http://www.doolinguitars.com/articles/neckdupe/
And for all the articals which is a must read IMHO.
PostPosted: Fri Nov 28, 2008 6:17 pm
How much do you want to spend? I suggest a CNC Router that way you're not limited by one neck shape. Or the other alternative is if you have a router table get a roundUNDER bit, not a round over, its the reverse. PM me if your interested I have a new one I don't use. I used it a couple of times thinking it would save some time by getting rid of the bulk before slapping it on the CNC, but it didn't so I abadoned it.
PostPosted: Fri Nov 28, 2008 8:23 pm
Hi Chris,
I use a few simple techniques to "rough carve" a neck. I use a "T" shaped jig - a 2X6 nailed to a base board that can be clamped to the bench. After the neck blank is tapered (jointer or tablesaw) I screw it to a 2X6 so the tapered edge is flush with the 2 inch side. This allows me to use a 1" roundover or bowl bit in a hand held router to round the neck by riding the router on the edge of the 2X6. I then use the Overholtzer method to rough shape the heel. This technique is similar to the old fashioned way to make cove molding on a tablesaw. I make the peghead separately from the neck using a modified bridle joint but these methods also work for one piece necks.
I posted some pictures a couple of years back at MIMF, but most of what I've posted there doesn't make the library.
PostPosted: Fri Nov 28, 2008 8:52 pm
Clay, last I heard, they were about 4 years behind in getting stuff to the library.
PostPosted: Fri Nov 28, 2008 10:00 pm
Clay a picture would help.
PostPosted: Sat Nov 29, 2008 7:59 am
They are working on a program that will transfer the the query files and put them into the library. Check the Jam Section as there is a discussion there that I ask the question about their progress. But enough about that. Let's see some jigs!
PostPosted: Sat Nov 29, 2008 12:09 pm
Here are a couple of pics of my deadhead sander. The idea was borrowed from Charles Fox. There's more info here http://www.chassonguitars.com/necksander.htm
PostPosted: Sat Nov 29, 2008 1:20 pm
My roundover set up is part of a larger fabrication sequence. I suppose it could be used as a stand alone operation, but for me it has it's specific place in the sequence.
Bear in mind that the way I do it requires the round over operation to be done before the fingerboard goes on. Many builders don't like to do that.
-C
Freeborn Guitars
and home of BeauGuard©
Users browsing this forum: CarlD, Colin North, J De Rocher, jfrench, JimWomack, TimAllen and 20 guests
