It is currently Tue Jul 22, 2025 11:43 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 27, 2011 9:26 am
Fillipo, I don't think your frets are fully bedded when you are doing the first leveling. My thought was to first just flex the neck before you fret so the frets will seat good. 0.1" sounds pretty good.
For fret leveling I've been using sandpaper on a flat object of one kind or another. Latest is a #5 plane body. I screwed up my first fret job with sandpaper on a level which led to my first re-fret. I like the idea of a nice flat, sharp mill file - and I have one in the shop that is either 8" or 10". I know exactly what you mean by being able to feel where the file is cutting and you just don't get that kind of feel with sandpaper. I'm going to try that.
Howard Klepper wrote:
One obvious solution to your problem is to do your second leveling the first time. ;->
... There has been a standardization of building methods in the past 10-15 years, in part perhaps because of the way it's taught at some of the guitar making schools. I think that is too bad, and that it allows one or two people's methods (at some schools, or in some book) to become gospel. I've noticed several times on this forum that when I offer a method for something that isn't what everyone else is doing, the person who made the inquiry is not interested. They only want to know about what "everyone" does.
As far as the quote above goes. I think most folks on the web look for consensus because there are always the one-off opinions out there and it is difficult to tell which ones are valid and which are not. Easier to take the main road. On the other hand, after hanging out at these guitar forums for 10+ years I've identified a handful of builders whose work and opinions I respect (Howard is for sure in this group). When these folks make recommendations, I pay attention.
PostPosted: Mon Jun 27, 2011 1:49 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
Todd Stock wrote:
the combination of large amounts of CA and air space under some tangs was not doing this guitar any favors.
Can you comment on that statement? I normally slot my fretboards deeper than the frets, then fill the sides with some stick shellack. Or are you talking about space between the frets and the top of the fretboard due to the "gunk" between them?
PostPosted: Mon Jun 27, 2011 3:57 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
The Doc Watson approach to fret leveling ...
Me, I like to have visual evidence of what is happening to the frets, and the best way to get that evidence is with an accurate 19" sanding beam with a high grade abrasive.
PostPosted: Mon Jun 27, 2011 4:56 pm
First name: Jonny
Last Name: D
I'd just like to chime in...
I neglected to chamfer the slots on my first build... had a hell of a time getting fret's to stay down..... and had to level twice as well....
I'll be chamfering my slots in the future...
Worst part is I'd read to do it... was planning to do so... and just forgot in the heat of the moment.....
PostPosted: Mon Jun 27, 2011 7:03 pm
First name: duh
Last Name: Padma
Deegatron wrote:
I neglected ...
Oh ya, lots of stuffs get forgotted in the heat of the moment.
Maybe thats why we has them moments...you think?
bliss
blessings
PostPosted: Tue Jun 28, 2011 9:48 am
"3) too heavy a hammer could be bouncing the frets during install."
To an extent I agree, but - does it not depend how hard you use it. I feel a heavier hammer with a lighter hand can work well.
PostPosted: Tue Jun 28, 2011 10:19 am
Many years ago, I built a Don Teeter String Compensation Jig. This is similar to the Earlwine jig. I made it for a particularly troublesome bass neck with crooked grain that took a dog leg bend when strung to tension. But since then I use the jig for every fret level job because it helps me get slightly lower action than doing without. This is more useful for electric guitars where the players want super low action, but it benefits my acoustic builds and re-frets too. It also is useful for classical guitars without a truss rod because it gives you a way to level the fretboard without string tension.
PostPosted: Wed Jun 29, 2011 12:32 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Todd Stock wrote:
Both...I get much better tone from fully bedded frets that from those installed dry.
Am I right in assuming that you bed your bridge saddles in hide glue too?
PostPosted: Wed Jun 29, 2011 10:29 am
First name: Nelson
Last Name: Palen
Why not make all the frets adjustable height as in bridge/saddle on an archtop?
(Ducking and running now)
