It is currently Wed Jul 30, 2025 5:57 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 27, 2014 7:51 pm
+1 on Colin's technique.
When I started building from scratch 10 or 12 years ago I actually ordered a set of unbent but profiled sides from Martin for an OM and Dred. Used them to make plexiglass templates.
Now you can get plans for almost any body shape that has the side profiles printed. Just photocopy them and make a template. If not available Colin's technique is great and the other techniques mentioned should work well too.
I have always profiled before bending and left them just a little longer on each end. You can put a piece of tape on your bending form, your half template, or your mold to accurately mark the waist and ends and then transfer those marks to the unbent side and/or template.
I just profile the back and leave the top dead straight. The minimal profile sands in quickly during radius sanding.
If you are using the same wood for binding (which I like) you can cut your binding strips before you cut the profile if the side is wide enough.
I usually clamp the side and template into a jig after cutting on the bandsaw and finalize the shape with a flush trim bit on the router table but that's probably overkill.
I leave the end blocks a little long and sand them down when doing the radius sanding.
PostPosted: Sat Jun 28, 2014 2:58 am
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Zip/Postal Code: 98368
OR....you can go to Waldron Instruments and you will find an extensive selection of side profile templates made by Kevin Waldron with the dimensions taken from actual Gibson, Martin, Taylor, (and selected others) guitars.
You can cut slightly oversize and still be streets ahead by using the actual profile. After bending, a sessionb of skimming on a radiused workboard and presto....
Make you life easy.
PostPosted: Sat Jun 28, 2014 3:14 pm
https://www.youtube.com/watch?v=pz6xzVRA51E
I also pre shape the sides here is a video on how I do it
PostPosted: Mon Jun 30, 2014 8:38 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I think there were basically two questions here. How do you profile the sides, and do you do it before or after bending. I have seen Mike's post before, and basing the profile on the radius dish makes a lot more sense than just using plan if you are in any way planning on using the radius dish down the road. The height (depth) at both end blocks is still determined by the plan. So I'm going with that. I'm still undecided on before or after bending. I've always done before.
PostPosted: Fri Jul 04, 2014 7:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I just finished up my first cutaway bend using Collin's preshaping technique and is was amazing.
Thanks!!
Users browsing this forum: ballbanjos and 17 guests
