It is currently Wed Aug 13, 2025 11:52 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Mon Apr 14, 2014 11:29 am
First name: Wendy
Last Name: W
State: Arizona
David, I think I would have to do a lot of practicing before feeling confident enough to crank the height adjustment while the fingerboard is moving through the thickness sander, but I am curious and may play around with it this weekend. I've got the Performax 16-32, which is basically an earlier version of what you have. Just curious, what is your typical taper from nut to 12th fret?
PostPosted: Mon Apr 14, 2014 11:41 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
David LaPlante wrote:
... I put the basic taper in my fretboard by running it through my 16-32 Jet sander and cranking down the height adjustment steadily as it goes through ...
Thank you for this idea! The speed of the belt is constant and I know the height adjustment for each 1/8 revolution. It would not take very much practice to be able to consistently turn the crank the correct amount within the time it takes the fret board to pass.
PostPosted: Mon Apr 14, 2014 12:41 pm
First name: David
Last Name: LaPlante
Wendy,
My boards typically are about 6.5mm at the nut to 4.5 or so at the 19th, thus around 5.5-5 at the 12th.
This is one of the variables that I can control to adjust for the desired action height and to keep the general construction (top dome, bridge height etc.) constant.
John, remember that this is done incrementally!
cron
