It is currently Thu Aug 14, 2025 4:20 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 24, 2014 8:23 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Here's a picture of one that I copied from Dan Miller. He posted it on the New Builder Challenge. Made from an old plane frog and so can be adjusted just like a plane. It's one of my favourite tools.
Quote:
We are all in the gutter but some of us are looking at guitars.
These users thanked the author Joe Sallis for the post (total 2): mkellyvrod (Thu Feb 27, 2014 2:41 pm) • Colin North (Wed Feb 26, 2014 4:53 am)
PostPosted: Mon Feb 24, 2014 3:37 pm
First name: John "jd"
City: Santa Barbara
lee valley makes a simple scraping tool for this:
http://www.leevalley.com/us/wood/page.a ... cat=,69873
PostPosted: Mon Feb 24, 2014 4:36 pm
Last Name: Russell
State: Michigan USA
I guess that is good if you have money to burn...
Mine didn't cost a penny and it pretty much does the same thing.
But I have to admit, theirs is prettier [clap]
@Joe Sallis, That is some beast there... Both yours and Arnt Rian's look like they would work quite well.
Bob
PostPosted: Tue Feb 25, 2014 8:47 am
First name: joseph
Last Name: sallis
Country: UK
[quote="
Bob[/quote]
Quite well is an understatement.
PostPosted: Tue Feb 25, 2014 11:34 am
[quote]I guess that is good if you have money to burn...
Mine didn't cost a penny and it pretty much does the same thing.[/quote
I don't think one would have to have money to burn to buy that. $60 is pretty reasonable for that. My time is about $45 per hour. Yes yours is simple and simple is elegant and I would most likely adopt your method but you have done the R&D. How much time did you spend with: posting about this on the forum, doing the drawing for the sander, making your blocks, trying the tape, etc. I am the beneficiary of your efforts but I bet you have more than $60 in this.
I am only reacting to the statement of "money to burn." I think that tool is a reasonable and viable solution for someone. That said I have Delron , Nylatron, UHMP, around so I will use your method. [:Y:]
L
PostPosted: Tue Feb 25, 2014 12:55 pm
Last Name: Russell
State: Michigan USA
@Link Van Cleave,
I said that because my money is going into much larger things than perfling cutters. I have been repairing guitars for over 20 years but not professionally. I just recently started my business because I have been getting more and more work over the last few years. So that $60 is more wisely spent putting into my shop for new equipment like say... a new bandsaw to replace my 45 year old dying one, or a thickness sander so I don't have to use my hand planes every time I need to thickness something, or maybe a side bender so I don't have to bend stuff on a hot pipe anymore.
Since I have been pretty much forced into retirement by our economy this shop is about all I have. I don't have a steady flow of clients coming through the door so I do have the time. No one is paying me $45 an hour to sit around so rather than make no money when I don't have the work I can (and do) try to make as many tools as I can. I am just getting into building guitars and as I am sure you know it is not cheap.
On the other hand if I did have a steady flow of clients then I completely agree with you, my time is better spent making money
And besides I really enjoy it when I can make something that works well and I am able to pass the idea on to others [:Y:]
So, Time? I have plenty, Money? Not so much... (or have more important places it can go)
I am glad you like the idea enough to want to make one. It will save you $60... laughing6-hehe
Cheers,
Bob
PostPosted: Tue Feb 25, 2014 1:22 pm
First name: EddieLee
Last Name: Brown
Time and money, it always seems like I always have more of one than the other. Right now it seems like I have no time but some money. And I have started making both bindings and purfling. I think the bindings are in good shape but the purfling will need some work. As soon as I have time. idunno That little Lee Valley's scraper looks like what I have been looking for. So thank you for that.
I'm also very interested in the original post. I will look closely at that and see if I can apply it to my purfling needs. Thank you for that post.
Happy building [:Y:]
_____________
EddieLee
PostPosted: Tue Feb 25, 2014 1:42 pm
Ha!
That tool from LV is so like what I was scratching my head to 'invent', but was way too lazy to build, so my blocks are a 'good enough' solution...
Nice to know I was on the right track...
PostPosted: Tue Feb 25, 2014 2:54 pm
Last Name: Russell
State: Michigan USA
@EddieLee
Isn't that the truth. I have been through times where there have been an over abundance of each and neither one is a good situation. I am fortunate that I am somewhere in between right now. But it took me 60 years to get here... laughing6-hehe
I posted a more detailed explanation of what I have in the Fixtures section called Easy Perfling Strip Jig if you are interested in more details.
@meddlingfool,
Yes you are correct, If it is good enough and works well you can't ask for more than that. Much like my side bender, A piece of 2 1/2" stainless steel exhaust pipe I pulled from the muffler shop down the road and a heat gun. It seems to do the job until I can buy a heat blanket and controller.. "Good Enough" [:Y:]
And your sanding blocks are what gave me the idea. I made one and it worked just fine but I don't like sanding dust so I use my scrapers in place of sandpaper when ever I can. There is an advantage to using the scraper on those strips, you don't get sanding dust under the strips so you don't have to keep cleaning it out. If you look in that picture I shot you will notice a nice neat pile of scrapings behind the strip.
But thanks much for sparking the idea. [:Y:]
Bob
PostPosted: Tue Feb 25, 2014 3:11 pm
It's a shame I still haven't figured out how to get a proper edge on a scraper....:)
PostPosted: Tue Feb 25, 2014 3:57 pm
Last Name: Russell
State: Michigan USA
I had a bit of an issue with that also at first but I wasn't using a proper burnisher... I was using a very old round punch thinking it just needed to be good steel. Then got one of those all in one burnisher and it made my life easy. You do need to treat them much like a plane blade by occasionally flattening the back and squaring up the edge. I always made the mistake of pulling the burr out too much thinking it was going to cut really well.... wrong.... If you pull it too much you will mash it down the first couple of scrapes you do. So just a little rub on the edge and a quick slice at about 15 degree angle is all it takes. You should just barely be able to feel the burr. The trick is to have a good burnisher. Now I can put an edge on my scraper in just a few seconds.
I have also seen guys not even burnish them but just put a file lengthwise on the edge of their workbench so it just sits proud of the bench top. Then lay the scraper down on the bench and slide it across the file. It makes a nice square edge with does cut pretty well but it just doesn't last long.
Bob
PostPosted: Tue Feb 25, 2014 11:44 pm
Maybe this will help. http://www.youtube.com/watch?v=667p5az9dps
L
These users thanked the author Link Van Cleave for the post: mkellyvrod (Thu Feb 27, 2014 2:37 pm)
PostPosted: Wed Feb 26, 2014 4:56 am
Quote:
Good tool idea Joe, thanks for sharing.
I just happen to have a USA Stanley 4 1/2 with a cracked body and was looking for something to do with the other bits.
All I need now is the bench!
PostPosted: Wed Feb 26, 2014 6:50 am
Get a car/truck exhaust valve. Cheap but effective burnisher.
PostPosted: Wed Feb 26, 2014 5:42 pm
Who am I to advise you, and I know this isn't really the right/normal way to do it, but I'm currently getting a decent edge on a scraper by squaring it up with a coarse Stanley oilstone on a shooting board, then clamping it in a vice and pressing the piece of hard round steel along the edge. I seem to be getting better results that way than with the Veritas variable burnisher I got at Christmas! Even less ideal, but I've got a fairly decent edge with a knife honing steel.
I also found one of my steel rulers to be an excellent scraper. And the burr doesn't seem to disappear either! And to think, at first I didn't like the ruler because of the burr! :lol:
PostPosted: Thu Feb 27, 2014 5:21 am
First name: joseph
Last Name: sallis
Country: UK
Colin, like a wrote originally I stole the idea from Dan Miller. Even the picture is not mine, it's his. Mine does look exactly the same, except the frog is not so rusty. With a table saw it took me less than an hour to make.
PostPosted: Thu Feb 27, 2014 2:40 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Guys, several great suggestions in this thread. Thanks! Up till now, I've been buying pre-made purflings, but I've got to give this a try.
Link, that's a really nice video!
PostPosted: Thu Feb 27, 2014 5:34 pm
Last Name: Russell
State: Michigan USA
Hey Link, Yes thanks for posting that video.
I have always pulled the burr out from the face of the scraper, I guess you would say the "traditional" way it is always shown.
One thing I have always done is scrape backwards. I started doing it a long time ago when someone showed me how you can see the scrapings coming off the scraper so you can judge better where you are scraping. Now if I try to do it the "right" way I feel like I am working blind.
Does anyone else pull their scraper rather than push it?
I will have to give your way of putting the burr on and see how it works. It appears it would be much easier.
Cheers,
Bob
