It is currently Mon Sep 15, 2025 5:40 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 03, 2011 9:05 am
I just buy mine from Shane, and it's nearly perfectly quartered, and with minimal runout, so I can just saw it.
PostPosted: Fri Jun 03, 2011 9:10 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Split- saw.
I end up with some kindling.
PostPosted: Fri Jun 03, 2011 1:09 pm
James Orr wrote:
My brace wood from High Mountain Tonewood usually comes perfectly quartered, so no need to split.
One splits to avoid runout, James, not to get it quartersawn.
PostPosted: Sat Jun 04, 2011 8:25 am
I split, then saw to follow the grain lines as long as they are straight. Anything with runout is discarded.
PostPosted: Sat Jun 04, 2011 9:18 am
First name: Darryl
Last Name: Young
State: AR
I'll ask a question about this.
I tried splitting a billet near the edge and it didn't want to follow the grain line (split would veer off toward the near edge of the billet). So I moved and tried splitting from the center of the billet and that split seemed to follow the grain line perfectly. Not sure how to split the billet along the grain line and remove only a narrow portion sized appropriate for a brace. I then used the split line on each half as the reference to cut bracing strips on my bandsaw. I finished up by running the braces through the drum sander to get the sides parallel and then trimmed each edge on the table saw to be 90 deg to the sides.
Does this sound like the best way to do this? Not sure how to improve this as I had no luck getting a split to follow the grain line when started near the edge of the billet.
PostPosted: Sat Jun 04, 2011 10:07 am
Country: Romania
You can't really split without following the center rule idunno It is often less than ideal as it might not suit your needed sizes resulting in more loses. However i see nothing wrong with sawing the face grain. The only side that really benefits from splitting is the side grain.
Build log
PostPosted: Sat Jun 04, 2011 10:42 am
One thing to remember about spltting bracewood to elimate runout, is that it is best to split both parallel and perpendicular to the growth ring. Runout is equally likely to happen in either direction, unless you start wirh a split billet. Then just split perpendicular to the already split face.
Chuck
PostPosted: Sat Jun 04, 2011 10:52 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Split and saw.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Jun 04, 2011 11:35 am
First name: John "jd"
City: Santa Barbara
Splits from the edge can run off the edge because you are splitting a narrow, flexible piece off a big stiff billet. Instead of splitting thin braces off the edge, start in the middle and keep splitting the resulting pieces from the middle until everything is close to the thickness you want.
-jd
PostPosted: Sat Jun 04, 2011 12:07 pm
Split on a radius of the tree, at 90º to the rings.
PostPosted: Sat Jun 04, 2011 12:49 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Yep, I split mine that way. I believe there's some confusion in this thread about what runout actually is, and why some of us hand split bracing. (as well as top billets) I used google to find these 2 pictures.
Vertical grain (1/4 sawn) is independant of runout. One has pretty much nothing to do with the other. It's easy enough to saw something along the grain. Splitting (at a 90 degree angle to the grain) will pretty much follow the direction the wood grew, eliminating, or reducing runout. I hope I explained this OK.
PostPosted: Sat Jun 04, 2011 1:03 pm
First name: Hugh
City: Lake Oswego
State: oregon
Split by halves.
PostPosted: Sun Jun 05, 2011 1:11 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
Vertical grain (1/4 sawn) is independent of runout. One has pretty much nothing to do with the other.
Well, not exactly. If a spiral tree is split radially, the surface is twisted. In flattening the surface of a wide board (as for a guitar top), the grain will no longer be vertical over the entire width on both ends. Also, there will only be one point on the width of the board where the runout is zero. But those facts are not an issue with narrow stock, as used for bracing.
There is no practical reason to split parallel with the growth rings, since any runout in that plane can be easily seen.
Runout in the radial plane can also be seen in spruce, but it does require closer inspection. With some magnification, the ends of the rays and transverse resin canals are visible on the tangential surface. The rays are short lines, but the resin canals are longer, and provide a better reference for determining the grain direction.
PostPosted: Sun Jun 05, 2011 11:27 pm
That's the way I understood runout. Having to do with the tree growing in a radial in center axis relationship to the trunk of the tree. Really impossible to see in the quarter sawn growth rings. Thus the need for splitting. ...in my understanding, such as it is!
PostPosted: Mon Jun 06, 2011 12:21 am
I only split till I get close to the dimensions I need and then plane and crosscut to length. Because I am building classicals I need very small braces to support a thinner than steel string top and would rather waste bracewood splitting to size than have braces with runout. I dont saw my braces only because splitting to size for me is nearly as fast as sawing
Having said that, I have bought bracewood from a number of sources including wood from High Mountain and LMI and I have never gotten bad bracewood from LMI or Shane.
PostPosted: Mon Jun 06, 2011 11:29 am
First name: David
Last Name: LaPlante
I saw mine, but only from really excellent straight grained and well quartered old stock. Presently I have a number of (30-40 years old) European violin top blanks that I'm using for top bracing.
Personally, I don't think a little run out in top brace wood is a big deal. I test for hardness and stiffness (which I think is far more important) and usually when I shape these I can plane easily in both directions on a side, a good indicator of very little or no run out.
My favorite test is to toss the cut braces on my concrete shop floor and listen to the sound they make ("clink" test).
You can really hear the difference in the stiffer and denser stock from any that are less so.
PostPosted: Mon Jun 06, 2011 3:40 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Zip/Postal Code: 63017
Count me in the split then resaw group also.
Users browsing this forum: No registered users and 61 guests
