It is currently Tue Jul 22, 2025 8:24 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 12, 2011 12:30 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
It's a tiny piece of wood,
that doesn't weigh much,
and the string balls are pulling it up anyway,
so?
PostPosted: Thu May 12, 2011 12:55 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
It looks like you could easily remove the bridge and then heat up your plate area to remove it too, since there is no finish yet to worry about, Then cut a new plate to fit where it should and glue it in. The tricky part is of course fitting your hand into what looks to me like a small diameter sound hole. If it were me and I couldn't do this I'd widen the hole. I like them bigger anyhow. It shouldn't be any harder than repairing a brace really. My two cents.
PostPosted: Thu May 12, 2011 5:49 am
pulling a plate is not that difficult. There are 2 ways to do this. One is to take a wet cello sponge that is cut in the shape of the plate , lay it on the plate and let set for 24 hrs and check. Sometimes it takes 2 days to soak through the maple . The plate slips off nicely. The other method is to get a plate heat blanket and apply heat . Set it for about 250 degree and in 10 minutes it should be off. You clean off the glue and make a new one .
Many ways to do this . Pick the way you would like to go about it . I find artist pallet knives a good took for working under the plates.
PostPosted: Thu May 12, 2011 9:20 am
I'd be worried that enough heat to remove the bridge and plate (if heating from the top which may be an incorrect assumption on my part) would separate the top seam and possibly the bracing...I'm leaning in Howard's direction even though I'm clueless about the lignum v... :D
PostPosted: Thu May 12, 2011 11:29 am
alan stassforth wrote:
Why not, Howard?
Hard to glue. More overkill.
PostPosted: Sat May 14, 2011 2:12 am
FWIW, my 1955 Gibson has a bridgeplate extension.
PostPosted: Sat May 14, 2011 2:13 am
I was just going to mention that. Loads of Gibson have bridge plates placed incorrectly, or from design changes mid production.
