It is currently Fri Aug 08, 2025 12:43 am
PostPosted: Mon Mar 22, 2010 10:47 pm
Last Name: Farmer
City: Durango
State: CO
from a re-fret point of view, bound boards I find much easier. Anything that avoids finish issues Is a blessing [xx(] . getting metal flush with finish that might be .003" thick is hard to do fast enough to make money.
PostPosted: Mon Mar 22, 2010 11:47 pm
Last Name: Abercrombie
JohnAbercrombie wrote:
4) If you are going to trim the tangs short anyway, you have lost 90% of the time advantage over binding.
I guess I didn't make this very clear.
I find that gluing the binding on the fingerboard and doing a bit of glue cleanup takes very little time. It's cutting the frets and trimming back the tang the right amount that add time over just setting full-length frets.
If you are planning on filling with dust and CA, you have to trim back the tangs, so have not gained much time over a 'full' binding job.
I also didn't think about the Gibson (?) style binding which is added outside the frets and shaped to match the fret profiles.
I never 'got' that idea at all.
PostPosted: Tue Mar 23, 2010 1:20 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
John, have you seen the fret tang removal tool from LMI? It saves TONS of time. I picked one up at the GAL conference a couple years back and now wouldn't part with it for love or money. No messing around with tang trimming nibblers, just shove the fret wire into the hole to the depth you want (you can rig up a stop if you're ingenious), then have at it with a few strokes of a file and you're done. Easy peasy.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Tue Mar 23, 2010 2:04 am
Cheers,
Dave F.
Dave-
Thanks for that tip about the LMI tool.
[:Y:]
I think I saved myself about $110.50 (US) with mine, though!
(And, no waiting for delivery, either!)
Left thumb presses on the metal bar- right hand holds the file.
PostPosted: Tue Mar 23, 2010 3:04 am
Last Name: Fifield
City: San Jose
Nice one John!! [:Y:] [clap] [:Y:] [clap] [:Y:]
Is that part of an old drawer slide?
Why didn't I think of doing it like this..... [headinwall]
Next time, before I buy a tool, I'm going to check with you first! :D
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Tue Mar 23, 2010 10:24 am
Thanks, Dave!
I just looked in the 'scrap metal' bucket and saw a length of 'shelf support' that did the trick.
That steel U-section comes in lengths and is commonly found here inside cupboards with adjustable shelves.
Any metal scrap would do the trick, I think.
I played around with 'nibblers' and 'nippers' and I thought the results still needed filing, so LMII is correct with the write-up on their tool.
