It is currently Thu Aug 14, 2025 3:41 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 25, 2009 7:13 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Fish Glue !
No heat ,no problems,high tack !!
the new Gorilla white glue works great !
high tack -drys clear-and is available in most hardware stores.
There are only a handfull of glue makers in this country!
The Titebond Co.
The Bordens/ Elmer Co.
for 2 of the most recogonized ones.
I would think a little wood supplier in Ca. buys in bulk from one of these suppliers.
So the product would be the same -hopefully as the suppliers glue.
beehive
I have used Lmii's white for years and love it!
My 2 cents!
Mike Collins
PostPosted: Sat Apr 25, 2009 8:10 pm
Last Name: Hodge
Mike,
I've never tried Fish Glue. Where would be the best source for that? I'm also in search of the supplier with the best pricing on the West System Epoxy. I'm not confident that my current source has the best price. :)
Bill Hodge
PostPosted: Sun Apr 26, 2009 6:23 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
The only fish glue source I know of is Norlands. https://www.norlandprod.com/Fishdefault.tpl but there's probably others. I think it's ironic that fish glue disolves in water, but fish don't :D
PostPosted: Sun Apr 26, 2009 6:36 am
Some do and some don't, depends on their 'scale' of sole-ubility I guess. Oh, never mind, just angling for the halibut. laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe 8-)
PostPosted: Sun Apr 26, 2009 8:24 am
You can also get fish glue here: http://www.leevalley.com/wood/page.aspx ... ,110,42965
I'm using it for my first build, so far with apparent success.
Joe
PostPosted: Sun Apr 26, 2009 8:28 am
A lot of thought and work went in to my glue tests and were originally meant for my own learning. It was only recently that I posted them on my website for anyone to read. I had nothing to gain for promoting one product over another nor was the article intended to sway anyone's choice. All glues were purchased by me and I have never received any produts or compensation in any form.
The reason I chose steel for the tests was to eliminate wood's inherant varibility. I used hot hide glue exclusively for a number of years after experiencing some "issues" with Titebond's original formula. There was a significant and discernable change in my guitars overal performance after that switch which was enough to convince me there was a difference in glues and their tonal properties. This change is what initially sparked my interest in testing glues.
There is and will always be "spectulation" as to which product is best for the particular application. My testing was meant to eliminate hunches, gut instinct, spectulation and guesswork and focus on scientific fact to allow me to choose a glue for my guitars. The Ah-Ha moment was actualy seeing the vibration spectrums of each glue. There is no way to manipulate these spectrums and WYSIWYG. [uncle]
tim...
PostPosted: Sun Apr 26, 2009 8:43 am
Last Name: Hodge
Howdy Tim,
I for one am thankful that you took the time and effort to do all the testing. Your's is the only I've seen to do such comparisons. :) From your second report, did I understand correctly that you have switched to LMI's white glue? I've been contemplating the use of it instead of Titebond. If you do use the LMI, what is your preferred method of gluing up Cocobolo? I've always used Titebond for that with success but am wanting to move away from it to things more specifically proven successful in lutherie. In addition, have you used Fish Glue at all, and what are your thoughts on it? I have great respect for your experience and opinions on this. :D
Bill Hodge
PostPosted: Sun Apr 26, 2009 10:45 am
Tim,
I too appreciate the testing and your willingness to share your results. I hope I didn't make it sound as if I thought you were pushing any of the glues with your results. Your write-up struck me as unbiased and informative. Personally, I've made the switch to LMI white as a result of your testing. Thanks again for the info. [:Y:]
- Flori
PostPosted: Sun Apr 26, 2009 2:45 pm
First name: Darryl
Last Name: Young
State: AR
Tim,
I appreciate the testing you did and that you posted the results.
I'm curious if you have tested fish glue.......and if you did, how close it was to HHG? I would test it myself if I had access to a hardnes and vibration testor.
Again, I apprecite you sharing your data.
PostPosted: Sun Apr 26, 2009 7:42 pm
Hi guys,
Thanks for the kind words and glad you found the articles helpful in your work.
Bill,
I have glued up dozens of sets of Coco with LMI white and have never had any issues. As soon as I run the gluing edge through the jointer I glue up the joint immediatley and don't allow it to oxidize which may be where folks have some less than satisfactory results. About a year ago I abandoned the use of hide glue used on top braces for LMI white. I still use hide for bridges but don't ask why... I just do for no particular reason?
Sorry but I have not tested fish glue but will gladly do so. Someone posted the link above, to several fish glues but which one of the fish glues are y'all using?
tim...
PostPosted: Sun Apr 26, 2009 9:18 pm
Tim,
Norlands makes the fish glue and re-packages it for Lee Valley and I believe anyone else who sells it. If you only want a little bit, give David Collins a call, he buys it in somewhat large quantities from Norlands and he might just sell you a couple of OZ's.
PostPosted: Sun Apr 26, 2009 9:32 pm
Tim, why did you switch to LMI white for braces?
PostPosted: Mon Apr 27, 2009 8:09 am
There aren't any discernible [tonal] differences to justify the hassle of using hide glue on top / back braces IMO. White is sooooo much easier and quicker to use. After I saw the nearly perfect vibration decay spectrum on the vibration bump test that eliminated all doubt in my mind as the right glue to use on my guitars.
Rod,
Will do. Thanks for the info.
tim...
PostPosted: Mon Apr 27, 2009 8:36 am
Last Name: Hodge
Rod,
My sentiments backed up by the thoughts of a Master Luthier. :D
Bill Hodge
PostPosted: Tue Apr 28, 2009 4:05 pm
I used Titebond on all my instruments up till about 2000, when I used LMI for one, then went to hide and I'm not looking back. They are plenty strong, and they all release with heat. I believe if you use any one glue, and learn all it's ins-and-outs, your guitars will be fine.
The only problem I've had, was with Titebond gluing a sq. steel rod in the neck. The rod rusted and became loose. Pilot error, not the fault of the glue.
I use epoxy for CF rods in the neck.
Last few guitars I've used hide for the fretboard w/o problems. I leave the neck shaft thick till the fretboard is glued on, no bowing, either 12 or 14 frets, with CF or truss-rod. Hide just doesn't seem to induce any bow.
I always got bowing with Titebond, but I figured on it, and profiled the neck accordingly.
I didn't get bowing with LMI glue.
Anyone read the American Lutherie article about Joseph Curtin, the violin maker? He almost apologetically told of using Franklin Hide Glue, and for about everything. He said he trusted it and got "warm fuzzy" confidence in using it.
PostPosted: Sun Oct 17, 2010 7:26 pm
Last Name: A
Mike Collins wrote:
Fish Glue !
The Titebond Co.
beehive
My 2 cents!
I have been thinking the same thing - I don't have anything to order from LMI - I don't want to put in an order just for glue. LMI does not make glue - so what is it then ? Is it the same a Gorilla's white glue ? I would be happy to use something local - rather than pay more in shipping than the product is worth.
I glued the back on my guitar - and of course I have a little bit of yellow glue around my linings, that can be seen from the soundhole - I would feel better if it were clear glue.
PostPosted: Sun Oct 17, 2010 7:49 pm
One thing I'll chime in with is that anyone using EmTech6000 as a finish will definitely NOT want to use Titebond anywhere on the outside of the guitar. EmTech6000 will shrink it! Does not appear to have that affect on LMI white though, so I've since switched to ALL LMI white.
PostPosted: Sun Oct 17, 2010 9:18 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I've just started on my first bottle of LMI white & so far, I really like it. Clear drying is a big plus.
It seems to slide a little less than AR glue & cleanup is a snap.
For Cocobolo, I'll stick with fish glue, but most other joints will be done with LMI.
I use West Epoxy for heel & tail blocks & fingerboard.
PostPosted: Sun Oct 17, 2010 11:30 pm
I reckon that LMI white glue may just be re-badged Weldbond......
However it must be stated here and now that I base my assumption on no more than a hunch and an itching of my left elbow which starts as soon as I see the two bottles side by side and only dissipates when I say something stupid.....obviously I never itch for too long. :ugeek:
Cheerski
PostPosted: Mon Oct 18, 2010 7:45 am
Tim McKnight recently stated some new thoughts on his acoustic glue tests. It seems that the "cracked engine crank shaft" analogy that was posted in this thread may have been what was happening in Tim's test.
For those who haven't see Tim's recent comment:
Quote:
Mario,
You bring up an interesting observation that I may have initially overlooked. I wasn't looking in the test results for a glue that had the same signature as the control coupon ... duh ... how did I miss that one? I was enamored with the nearly perfect bell curve of the spectrum's sustain and decay consistency of the LMI White glue that I may have overlooked the obvious that you pointed out. I couldn't really explain how the sustain time was actually longer with LMI White, as well as a few other glues, over and above the control coupon. That fact seemed to be clouding my judgement. The mass and weight of all coupons were nearly identical to the gram so that wasn't a contributing factor either. ...
PostPosted: Mon Oct 18, 2010 7:54 am
Re; Weldbond glue,
The address on my bottle states:
Frank T Ross & Sons INC
Toronto, Ontario
Canada.
It's a very good 'white' glue, drying hard and clear, looks, acts and smells like a PVA but seems to have something added that reduces the open time a bit, dry more crystaline and stick like poop to a blanket. I have used it in the past to fit plastic bindings and had no issues with any sort of de-lamination even after years. I seriously do wonder if this is in fact what LMI are using for their brand of glue.
