It is currently Sat Sep 13, 2025 11:49 am
 Post subject: What's in your sandwich?
PostPosted: Fri Jan 25, 2013 1:28 pm
Last Name: Ensor
City: Springfield
State: Missouri
I am considering switching to a fox style bender. What is your "sandwich" when using this type of bender? (e.g. slat, blanket, paper, wood, paper, blanket, slat)
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri Jan 25, 2013 1:44 pm
First name: Jim
Last Name: Kirby
From the bottom up:
Spring steel slat
wood - spritzed and wrapped in aluminum foil
aluminum flashing
heat blanket
spring steel slat
I like having the blanket on top of the wood so that it stays in contact and heats uniformly. I think some people prefer it underneath.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Jan 25, 2013 2:33 pm
from the bottom up also.
-heat blanket
-slat
-wood wrapped in paper, paper soaked in water after wrapping.
-slat
PostPosted: Fri Jan 25, 2013 2:34 pm
First name: Tony
Last Name: C
City: Brooklyn
Pretty much the same here. From the bottom up:
Spring steel slat, foil, wood, blanket, foil slat.
I no longer wrap the wood with the foil. Bending the folded foil causes it to crinkle which can leave marks in many types of wood. Instead, I use one sheet of foil cut lengthwise to make two discrete pieces or foil. No more crinkles. With oily wood, I will also use paper which again is cut lengthwise to avoid crinkling. Cutting the paper was a tip I got from this forum. I am pretty sure Todd Stock posted it, but I am not certain. It is a good tip, so thanks to whoever posted it.
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Jan 25, 2013 2:42 pm
For the paper I use the 6" wide rolls of light-brown paper usually used by painters in the paper/masking tape dispensers. Had some left over from painting the house and turns out it works well and is convenient.
PostPosted: Fri Jan 25, 2013 2:48 pm
From the bottom,
blanket, slat, paper, wood, paper, slat, blanket, slat. I cover the blue tempered shim stock slats with Al foil as well.
PostPosted: Fri Jan 25, 2013 3:06 pm
Slat, blanket, thermo couple, side and bindings wetted in foil, slat. I use 8 wood clothes pins to hold the assembly together during heating (the wood doesn't melt). I try to keep the blanket in direct contact with the side package. The clothes pins do a good job.
What are your target temperatures?
Cheers, Michael
PostPosted: Fri Jan 25, 2013 3:19 pm
From the bottom up...
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
Someone had to do it....
PostPosted: Fri Jan 25, 2013 3:26 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
Phew! I came this close (I-I) ! Thanks for taking the hit, Meddling!
Alex
PostPosted: Fri Jan 25, 2013 3:33 pm
Last Name: Ensor
City: Springfield
State: Missouri
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
Wow! wow7-eyes That's super thick. How much compensation did you have to allow for when making the bending mold? laughing6-hehe
PostPosted: Fri Jan 25, 2013 4:22 pm
Chris Ensor wrote:
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
You have any problems with springback [xx(]
PostPosted: Fri Jan 25, 2013 5:23 pm
Seems like a natural for making a grilled cheese!
PostPosted: Fri Jan 25, 2013 5:31 pm
First name: Big
Last Name: Jim
SteveSmith wrote:
Chris Ensor wrote:
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
No but Off Gassing can make for a rough build !! laughing6-hehe laughing6-hehe
PostPosted: Fri Jan 25, 2013 5:42 pm
A lot less springback since I went vegetarian...
PostPosted: Fri Jan 25, 2013 5:47 pm
First name: Jim
Last Name: Kirby
SteveSmith wrote:
Chris Ensor wrote:
Flaxseed
Mayo
Phoney balogna
Cheddar
Lettuce
Mustard
Flaxseed...
No, but after a few years, bending becomes a problem laughing6-hehe
Jim Kirby
kirby@udel.edu
PostPosted: Fri Jan 25, 2013 6:22 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Todd Stock wrote:
Spring steel slat, foil sheet, wet paper, dry wood, wet paper, foil, slat, blanket, slat
Me too. I bent my first 10 or so on a hot pipe. When I built my Fox style bender I copied the "sandwich" from one of Todd's videos. It works so I've never tried any other combination.
PostPosted: Fri Jan 25, 2013 6:23 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
You guys forgot salt and pepper
James W Bolan
Nashville Tennessee
PostPosted: Fri Jan 25, 2013 7:55 pm
I always used a pipe in the past but recently got a bending unit from John Hall. I've only bent two sets with it so far using slat/wood/slat/blanket as per his videos. Fast and flawless for the mahogany and Pau Ferro that I used. I can see using the paper and foil for highly figured or lighter woods.
PostPosted: Fri Jan 25, 2013 8:31 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
From the bottom
Slat/Blanket/paper/wood/paper/thermocouple/Blanket/Slat
I started using two blankets about a year ago. Working very well so far, but I've not
bent any really tough or highly figured sides yet. I like the idea of heating from both
sides. I had used foil for a while, but so far I don't see any problem without it. I wrapped
the foil over and folded the two edges together to make a sealed sleeve with the idea
of holding the water in the wood for a bit longer.
A little off topic, but don't forget SuperSoft II for the really highly figured stuff...
Gene
PostPosted: Fri Jan 25, 2013 11:55 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Mines is just blanket, steel slat, wet wood, steel slat, blanket with a thermo stuck in the mix. And down a home brew or 12 while watching the wood bake.
I loves me two blankets too.
PostPosted: Sat Jan 26, 2013 8:48 am
Not all blankets are the same. I use a 5 watt per sq inch. Wood gets hot it bends. I did modify my bending technique
Slat wet paper wood ( dampened ) wet paper blanker slate
the thermometer is under the top slat and on top of the blanket. With water in the mix you can get a steam reading not real heat so I want to know the heat of the blanket.
Some woods don't like as much water as other woods, Maple and Koa if made too wet can actually over bend. I will keep the blanket in contact with the wood and went the blankets reads 250F I bend the lower bout , I check the upper bout that things are still damp ( NOT WET) and then drive the waist cawl about 1 inch from the bottom then do the upper bout. By this time my heat is about 275 F then I finish the waist. Some woods will take more heat to set the bend than others so keep a log. I thin let the heat rise to 275 to 350 for most woods. Once I attain that temp I turn the heat back to about 200 to 230 to cook off the water and allow the wood to cool.
Mahogany and Maple , Padauck all seem to like more heat
Cocobolo will bend well at 250. Watch for soft spots. This can often lead to cupping. Also Super Soft is not a bad thing to have in your shop. As you can see by the posts , there is a common thread , wood gets hot it bends , so the key is time and heat duration. I am done bending in about 4 to 5 minutes from the time I turn on the unit.
There are many ways to do this so find the technique you are comfortable with. I will often bend my binding with the sides I am bending.
PostPosted: Sat Jan 26, 2013 11:10 am
Last Name: Ensor
City: Springfield
State: Missouri
What is the advantage of putting a slat in both sides of the blanket? Is it just for protection?
PostPosted: Sat Jan 26, 2013 11:18 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Yes,
I put the upper slat over the blanket to protect the upper blanket from being
torn as I pull the bending holddowns (?) across and down the upper and lower
bouts.
Gene
PostPosted: Mon Jan 28, 2013 3:04 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Bread
Ketchup and mustards
pickles
tomatoes
lettuce
mystery meat (could be beef, pork, chicken, dog, cat, rabbit, or whatever)
cheese
another mystery meat
more cheese
mayonaise
bread
Typhoon Guitars
PostPosted: Mon Jan 28, 2013 10:24 am
First name: Jim
Last Name: Kirby
I like to put something between the blanket and the wood because, without it, I do get an imprint of the blanket on the side. I just use a piece of light aluminum flashing rather than a real bending slat.
Jim Kirby
kirby@udel.edu
Users browsing this forum: Bing [Bot] and 28 guests
