It is currently Tue Aug 12, 2025 6:37 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: First Selmer Build
PostPosted: Sun Dec 25, 2011 7:50 pm
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
I am building this Selmer gypsy jazz guitar based on Michael Collins’ book, BUILDING A SELMER-MACCAFERRI GUITAR. I used the Charle plan for the original template and forms, and just received Collins’ plans to verify some things about the neck geometry.
Chuck Kish
 Post subject: Re: First Selmer Build
PostPosted: Sun Dec 25, 2011 8:14 pm
First name: Chuck
Last Name: Kish
Here's what I've done so far....
Chuck Kish
PostPosted: Sun Dec 25, 2011 8:23 pm
First name: Chuck
Last Name: Kish
...and some more...
Chuck Kish
PostPosted: Sun Dec 25, 2011 8:27 pm
First name: Chuck
Last Name: Kish
...and to finish progress up to this point....
...And that's where I am right now....
Chuck Kish
PostPosted: Sun Dec 25, 2011 8:48 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
nice! keep´em coming!
PostPosted: Sun Dec 25, 2011 10:14 pm
First name: Bruno
Last Name: Piancatelli
Country: Argentina
ill keep an eye on your progress.
im thinking of building one for my self.
so far very good
PostPosted: Mon Dec 26, 2011 8:15 am
First name: alexandre
Last Name: bouboule
City: Fontainebleau
Country: France
Hello
Be careful with the rf charles plan, the action with the radius of the braces on the plan is 5mm with the 18mm height sadle !
You have to increase the angle of neck/side to decrese the action.
PostPosted: Mon Dec 26, 2011 8:18 am
Last Name: bouboule
City: Fontainebleau
Country: France
Look here if you want http://www.benoit-de-bretagne.com/phpBB ... hp?t=10687
PostPosted: Mon Dec 26, 2011 10:39 am
First name: Patrick
Last Name: Hanna
State: Missouri
I'm glad you're documenting this project so thoroughly. I'll be watching it closely. I've never built one of these guitars but I do find them very interesting. Regarding your question on molds, yes, I think you'd be better off gluing the laminations as you stack them. You can still register everything with screws, cut the rough shapes and then glue up--re-inserting the screws to hold the lams in place while the glue is still slippery. Then route to clean up as you have done here. I don't know whether a lamination of plywood would stiffen your mold, but it seems to me your cross-clamping idea is an obvious and workable solution to that problem. You could also attach a "floor" to the mold, held with screws only. In that way, it could be removed as need for access to one side or the other. (Of course, several screws and a mold floor are probably more hassle than a bar clamp.)
Patrick
PostPosted: Mon Dec 26, 2011 10:55 am
First name: Chuck
Last Name: Kish
Michael Collins mentioned this and warned me about the high action in the Charle plan neck geometry. I have also found that the neck lengths on the Charle plan and Collins book differ by about 1/4". So, I am not doing any neck construction until I have finished the box and can measure the actual length to the bridge location. Thanks, rdpdo, for the link. I will take a good look -- good thing measurements aren't language sensitive. 8-)
Thanks, Patrick. I did consider the floor but as you said the clamps were a lot quicker. I did glue as I went on previous molds and the results were better, but the whole mold was more substantial. Next time, glue as I go.
Chuck Kish
PostPosted: Tue Dec 27, 2011 12:19 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I found the action high, too. I though that maybe it was me...
My fix was to make a lower bridge.
Do you have a link for Shelly's video? or is it easy enough to find. (its late and I'm traveling...)
http://redrivercanoe.ca/
PostPosted: Tue Dec 27, 2011 12:33 am
First name: Chuck
Last Name: Kish
Hi Douglas,
Check out:
http://www.youtube.com/watch?v=GAlwzwAjpW0&feature=plcp&context=C35c533cUDOEgsToPDskK6hQONq53Zf8I0pUPbIAuG
That should be the side bending video episode. She has episodes that go through the whole process on her "Parkguitars" YouTube channel.
Chuck Kish
PostPosted: Tue Dec 27, 2011 1:27 pm
This is great! I am building one of these too. Well actually i need to get started asap. I'd love to see a pic of you joining the top.
PostPosted: Tue Dec 27, 2011 9:30 pm
First name: Chuck
Last Name: Kish
Got a little more done. Finished the rim. Have not sanded the edges to fit the top and back yet. Will do that when I am ready to glue them so there is a fresh surface for gluing.
Chuck Kish
PostPosted: Tue Dec 27, 2011 9:39 pm
First name: Chuck
Last Name: Kish
This is the only photo I have of the top joining. I thought I had posted it. oops_sign What you don't see is the tape on the back. The plates are "clamped" with masking tape. Even the tape accross the joint on top is hard to make out in this photo. I used the same caul, shaped like the top of the pliage box to shoot the joint and under the top as it is being glued seen here. All of this was done as described in Collins' book. Except that I did mark out brace locations and run the plates over the jointer before bending the pliage to get them close. Had I been able to glue the plates together immediately after bending the pliage, I may have gotten away without even shooting the joint with the hand plane. Gluing is a little tricky with the pliage but not too difficult. On the inside I taped the part of the top above the pliage tightly together. Then, folded the joint open to apply glue. The bottom part of the pliage "butterflied" open. Applied glue, carefully put the joint together, laid the below pliage section flat on the bench and tape-clamped it together. Flipped it and tape-clamped the above- and below- pliage joint portions. Then the caul on the bench (packing tape to avoid sticking) laid the top down, flexible caul over joint and the gobars to keep the joint frmm "popping" and keep it aligned. The flexible caul is a piece of 1/8" plexiglass - one side with packing tape, the other with PSA 220 grit sandpaper. With the tape it doesn't stick to the top, and the sandpaper gives the gobars something to hold onto.
Like so many things, it was easier to do than it sounds. Did feel a bit harry though doing all this while the glue is setting. The joint came out pretty good.
Chuck Kish
PostPosted: Sun Jan 15, 2012 5:09 pm
First name: Chuck
Last Name: Kish
***ERROR ALERT***
Unless I missed something in the reading and diagrams, the Collins book has an error in the diagram on p95.
I made the donut as in the diagram but as finishing it noticed that is seemed small. It turns out that it is 1/2" wide, the same width as the rosette, so if you use it, you will rout the soundhole right up to the rosette. Here is the jig with both donuts.
Using the full scale diagram on p93 showing all the soundhole/rosette elements to make the donut comes out right. X marks the wrong donut.
That being said, having these full size diagrams in the Collins book makes it easy to copy and make the jigs that do the job.
Chuck Kish
PostPosted: Mon Jan 16, 2012 1:12 pm
First name: Chuck
Last Name: Kish
Progress update....
Routed the top for the rosette. Used center to test depth since it will be soundhole.
Cutting purfling strips from veneer for rosette and later body purfling.
Assembling the rosette in practice channel.
Bending the tighter upper and lower curves. How lucky is it that my bending pipe fits those curves almost perfectly?
Rosette ready for gluing. These dental type probes were great for pushing the purfling down tightly into the channel. I over flooded with CA so had a bit more mess to clean up than I should have, but it turned out OK (darker area is shellac to protect top).
Rosette clamped.
Planing (scraping too) to level the rosette.
Chuck Kish
PostPosted: Mon Jan 16, 2012 1:23 pm
First name: Chuck
Last Name: Kish
Finishing the rosette, fitting the ebony insert.
The roughed out ebony inset with the top fitted.
The inset fitted and ready for gluing. Scraping the rosette "dirtied" the top - glad I gave it some protection with shellac.
The finished rose and the tools I used for fitting the inset.
The rose is now leveled and the top sanded to clean it up. A little more sanding needed on the top -- for later.
I cut the soundhole after completing the rosette. Collins' book cuts the channel and soundhole at the same time without taking the jig off inbetween cuts to insure proper alignment. I was concerned about the area between the rose and the soundhole being thin and weak so decided to leave the soundhole cutting for after completing the rose. In retrospect, I think that with ample care either way would work fine. If/when I do it again I would do it the same way I did it this time. It was no trouble to realign the routing jig and waiting to cut the soundhole avoided any possible slips that might have damaged the delicate edge.
A closeup of the rose. I like these Selmer style rosettes, simple, classy (IMHO).
Chuck Kish
PostPosted: Mon Jan 16, 2012 1:45 pm
First name: Chuck
Last Name: Kish
Bracing the back.
I varied from Collins' book on the back arching. He arches the back into a 12 foot cylindrical shape. I am using my 15 foot radius dish and making the back just as I would a regular steelstring with a 15' radius. The difference in the amount of doming of the back is negligible though I realize the shape might be slightly different. Here are a few pics....
The completed back and the top yet to be final thicknessed and braced.
Chuck Kish
PostPosted: Mon Jan 16, 2012 3:16 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Really nice work. I'm not at all familiar with these guitars, but I'm intrigued.
PostPosted: Mon Jan 16, 2012 4:27 pm
Country: Romania
They have a very particular tone. I like them a lot, dreaming of building one too. Here is an example:
Build log
PostPosted: Mon Jan 16, 2012 6:53 pm
First name: Bruno
Country: Argentina
looking great
I´ll find this thread very useful on the short future.
thanks
PostPosted: Fri Mar 16, 2012 6:55 am
First name: Chuck
Last Name: Kish
Haven't updated in a while, so here's the recent progress.....
Gluing the back to the rim....
Sanding the angle on the neckblock before using the radius dish on linings. I built the back on a standard 15' radius dish rather than the 12' cylindrical radius called for by Collins. The difference in overall arch is negligible.
Chuck Kish
PostPosted: Fri Mar 16, 2012 7:06 am
First name: Chuck
Last Name: Kish
Putting on the soundboard....
Chuck Kish
PostPosted: Fri Mar 16, 2012 7:22 am
Looking real good York!!!
I can't remember if Collins book said so or if I got it on the net somewhere but did you lacquer the inside back and sides?
BTW I love that sanding paddle I'll have to steal that idea for my build ;)
Users browsing this forum: meddlingfool and 23 guests
