It is currently Mon Aug 18, 2025 4:52 am
PostPosted: Wed Jan 05, 2011 11:27 pm
Hey all, I've been away for awhile but have a quick question and will try and keep my head down. What's the best way to flatten the area above the soundhole where the fretboard is glued down to the top? I have a slight radius even though I braced it using non-radiused braces. I want that area of the soundboard to be flat so I can get a good joint with the fingerboard, but I'm not sure what would be easiest and most accurate. Any advice would be greatly appreciated.
Cheers!
PostPosted: Thu Jan 06, 2011 12:14 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
From Mike Mahar on Aug 20, hope this helps!
This jig is to flatten the upper bout so that the fretboard extension lays flat when the neck is set at the proper angle. The thickness of the flat board is the same as the thickness of my fretboard plus the height of the crown of the frets. In this case that is .30". The ebony bar that is taped to the bridge position is the same height as my bridge. There is PSA sandpaper stuck to the flat board. I just sand the upper bout until there are no gaps.
You can't always use this jig. If the angle of the upper bout is too far off, you will make the top too thin. In those cases I just sand the upper bout level and put a wedge into the fret board extension. When the angle is close, however, this jig works well.
Once the upper bout is sanded, you can simply take the angle between it and the side of the guitar and use that to set the angle of the neck. I use a flush mounted neck using threaded inserts on my neck. I can use an angle gauge to get the angle of the top and then set my table saw directly from that and then slice the end of my neck. Once that is done, the neck is now on the same line as the upper bout and the neck is pretty much "set".
ps. The square piece of ebony is from another attempt a making this jig that didn't work and I never bothered to remove it.
PostPosted: Thu Jan 06, 2011 9:04 am
First name: Martin
Last Name: Lane
City: Grand Rapids
Hesh tooted.
http://www.lenaweelutherie.info/page6/p ... age24.html
"...you have to get over your strict adherence to your largely imagined notion of absolute perfection..."
PostPosted: Thu Jan 06, 2011 9:09 am
I used a block plane - easy peasy.
If I was planning on making several, I'd make one of those jigs though.
PostPosted: Thu Jan 06, 2011 12:17 pm
Wow, great ideas guys, thanks for the info! I think I'll be building one of those jigs when I get home from work today. [:Y:]
Cheers!
