It is currently Wed Aug 13, 2025 3:50 pm
PostPosted: Tue Sep 21, 2010 8:37 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I have a good set of sitka spruce with a tight ring count that has a hairline crack about an inch long..I thought I would shellac the area and hit it with some thin ca....is that acceptable ??????
MK5acoustics.com
PostPosted: Wed Sep 22, 2010 6:55 am
My experience is that CA will cause a yellow stain on spruce.
PostPosted: Wed Sep 22, 2010 7:56 am
Don't add shellac.
Where is the Hairline and how long?
Does it terminate at the edge or not?
Can you flex and see it open on both sides?
PostPosted: Wed Sep 22, 2010 8:16 am
this is an easy repair . No on the shellac as stated prior and no on the ca . Tite bond or hot hide glue will work. No need to make it harder than it is .
PostPosted: Wed Sep 22, 2010 3:14 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
the crack is in lower bout area..its a thick piece of sitka, dropped and hit on one side ..I steamed it out and saw it had just a very small hair line crack...how would I use titebone..just kind of force it into the small crack as I flex it?????
thanks for the replys
MK5acoustics.com
Users browsing this forum: No registered users and 41 guests
