Haans wrote:
For years I have used a Dremel mototool in a Dremel drill press, but I have modified it to be more solid...it is still not solid enough, and I hand sand the ff holes to final size. I think the way to go is Proxxon, a much more solid system. Dremel tools are pretty crappy generally. I stopped at the local "big box" to look at them a few days ago, and 3 out of 4 of the demos had slop in the chuck bearings (actually in the housing as on one I could see the whole bearing move!). Several of my Dremels have slop, and a couple don't, but I wouldn't count on them staying that way. Should I ever upgrade, I would get the Proxxon.
Basically, a larger 3/4" board is fitted to the stand permanently, and a 1/8" pin is drilled into the board and centered under the bit. I made a mandolin ff hole template out of 1/4" plex, and it is double stick taped to the bottom of the top plate after it is completely carved. I use the grout removing bits (reground).
It does work really well, except for the flex, so I have made my template undersize. I think the Proxxon would do the trick.
The slop comes from the bearing not having a tight fit in the plastic shell. I put a strip of electrical tape around the bearing and when reassembled, it provided a nice tight fit, taking all of the slop out. Give it a try to see if it helps. It only takes a few minutes and is a very cheap fix.
