It is currently Sat Aug 09, 2025 8:12 am
 Post subject: Masking a neck
PostPosted: Thu Apr 29, 2010 11:11 am
How much of the fret board should be masked before spraying? I've masked the top and sides, but get a ridge of varnish when I remove the masking. I'm concerned about sanding it down too far.
 Post subject: Re: Masking a neck
PostPosted: Thu Apr 29, 2010 11:20 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I only mask the top of the fingerboard, finish on the sides of it is normal and the masking line is on the edge and sands of easily.
Fred
Fred Tellier
PostPosted: Thu Apr 29, 2010 1:44 pm
Ya, what Fred said.
PostPosted: Thu Apr 29, 2010 2:02 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Pretty much as noted by Fred. I mask the top of the f/b, exposing just a hairline of the top edge. After spraying and removing the mask, I run a small sanding block along the top edge to break the finish then clean up the top of the f/b with a razor blade. Makes for a very clean transition.
Ken
http://www.casperguitar.com
PostPosted: Thu Apr 29, 2010 5:23 pm
So do you fret before or after spraying?
PostPosted: Thu Apr 29, 2010 5:31 pm
I fret before. Some fret after.
PostPosted: Thu Apr 29, 2010 7:50 pm
I fret the board before I put it on the neck , Like Fred I mask off the top and clean up after. I don't like masking the sides , I want finish there and use the edge of the fretboard to be the separator.
Users browsing this forum: No registered users and 45 guests
