It is currently Fri Aug 08, 2025 3:34 am
PostPosted: Thu Mar 04, 2010 8:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, I am experiencing some painfull, expensive lessons with this type of tuner. Someone please tell me how you succcessfully load the strings without slippage?
PostPosted: Thu Mar 04, 2010 9:17 pm
First name: Peter
Country: England
I just get 3 or 4 wraps around the tuner before feeding it through the hole and then wind very slowly until it bites. With the bass strings I just get maybe 2 wraps depending on the gauge. been a while since I owned a steel string slot-head, but it always worked for me.
PostPosted: Thu Mar 04, 2010 9:35 pm
First name: René
City: Bossier City
State: Louisiana
Frets.com :
http://www.frets.com/FRETSPages/Musicia ... dstr1.html
René
PostPosted: Fri Mar 05, 2010 12:59 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you. They sure do not act like standard tuners, that much I have learned!
PostPosted: Fri Mar 05, 2010 3:04 pm
Maybe it's because I have had 4 slotheads but over the past 5 years but I have evolved back into the more simple method of stringing in the following manner:
1) Anchor the string ball in the bridge.
2) Pass the string over the tuner and clip at one tuner post north.
3) Bend the last 1/2" of the string past 90*.
4) Pass the bend through the shaft hole and keep tension on the string.
5) Wind while keeping tension and position its exit to pass as straight as possible toward its nutslot location.
6) I shoot for about 3 windings on wound strings and 5 on unwound.
I still use the locking method on vertical posts but have found the simple slothead method described above to work in all situations post stringing. I think keeping tension on the string throughout its winding is the key in getting it to grab.
PostPosted: Sun Mar 07, 2010 1:56 pm
First name: Jim Howell
Lots of good advice already.
Here is a link to a pdf at Taylor that can be printed.
http://www.taylorguitars.com/global/pdfs/Steel_Restring.pdf
Jim Howell
Charlotte, NC
PostPosted: Sun Mar 07, 2010 7:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If by "locking method" u mean making sure the string gets wrapped over, I am now doing that, much better grab.
Users browsing this forum: Colin North and 37 guests
