It is currently Sat Aug 02, 2025 8:55 pm
PostPosted: Thu Sep 10, 2009 8:09 pm
First name: David
Last Name: Engel
City: Stanwood
Hi All,
Those of you who specialize (or do more often than not) french polish as you choice of finish, do you finish the nech just like the body? I mean french polish the neck also?
God, Family, Carreer
PostPosted: Fri Sep 11, 2009 9:18 am
I do, so far.
PostPosted: Fri Sep 11, 2009 9:32 am
I have been using waterlox oil on the neck when I french polish the body and headstock plate.
Burton
Brookline, MA.
PostPosted: Fri Sep 11, 2009 9:36 am
yes, I FP the neck
PostPosted: Fri Sep 11, 2009 10:01 am
I abandoned FP on the neck playing surface in favor of Danish Oil. I've been satisfied so far after 2 years experience.
PostPosted: Fri Sep 11, 2009 10:34 am
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
TruOil on the neck........... much easier. Build up your finish; 5 - 6 coats, 0000 steel wool and wet sand w/ 1200; 5 - 6 coats and level again. Should be just fine by then.....
You can then FP the headstock and backplate (if you have one.)
Peter
PostPosted: Fri Sep 11, 2009 2:30 pm
So far i have always FP the neck when doing the body with FP.
PostPosted: Fri Sep 11, 2009 4:59 pm
If your intention is to FP the neck then yes the process is the same. I don't FP neck anymore. i finish all my neck anymore with medium viscosity Cyanoacrylate (super glue) it renders the slickest fastest neck finish I have found so far. Wears very well. polishes to a ulta high sheen or a satin sheen easily. i can have a neck finished, rubbed out and buffed out in 3-4 days ready to install
Users browsing this forum: dofthesea and 25 guests
