It is currently Mon Jul 28, 2025 3:39 pm
PostPosted: Tue May 19, 2009 7:38 pm
I noticed a crack in the back of one of my "factory" guitars near the headstock. I glued it 6 months ago with LMI white, but it appears to be back. I have LMI white, CA (thin and thick) and access to Titebond. No HHG though :cry:
Any suggestions would be appreciated.
Laurie
PostPosted: Wed May 20, 2009 7:49 am
Can you flex it open any more than that?
That is some squirrley grain in that neck. No wonder it broke.
PostPosted: Wed May 20, 2009 8:01 am
That is some funky grain. The problem is, now that there is white glue in there, any glue you manage to get in now wont adhere to the old stuff. Probably time to call in a professional to look at it first hand.
Jordan Aceto
Ithaca, NY
PostPosted: Wed May 20, 2009 2:14 pm
Last Name: Hodge
Laurie,
Who is the manufacturer? It's possible (if you're the original owner) that they'll replace the neck for you at an authorized service location. That's an obvious manufacturing flaw that should have been stopped at QC. They may even send you another neck if you want to take a shot at it but that would likely void any warranty if you have one. :D If there were no warranty and it were mine, I'd probablty make another neck for it just for practice. :) I wish you well with it.
Bill Hodge
PostPosted: Wed May 20, 2009 9:03 pm
Thanks for the replies. The grain is far from quartersawn, but the guitar is an entry level one, so I'm not surprised. The problem is this guitar is one of the best playing in the fleet (I have 11), so I'm quite partial to it.
As for the comments...
Barry: Yes, I can flex it open and close it with some elbow grease.
Bill: It is a "Simon and Patrick Luthier" S&P6 spruce/mahogany. I am not the original owner, but I think it was played 6 times before I bought it. I figured they would say I dropped it and cuased the crack (which I didn't), so I haven't pursued it yet. I'll check with a dealer for fun to see what they say...
Laurie
PostPosted: Wed May 20, 2009 9:23 pm
shoot them a line, you have nothing to loose.
PostPosted: Sat May 23, 2009 8:47 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Hi Laurie,
Simon & Patrick is made by Godin guitars in Que. It's similar to Seagull(another of their line) so I would think that the neck is a bolt on with the F.B. ext. glued. I've replaced a couple of Seagull necks under warranty so you may be able to get one through the dealer that you purchased the guitar from and install it yourself. The install is straight forward and the only thing you will need to do is floss the replacement neck to ensure the angle and the fit is good.
Go for a warranty replacement neck it's worth a try, but even if you have to buy one it shouldn't cost too much. If the dealer won't cooperate, go direct to Godin, they are very reputable.
Cal
PostPosted: Sat May 23, 2009 9:20 pm
I've seen this repair done many times over the years. I think you use a screw or a bolt or something. gaah
Users browsing this forum: phavriluk and 14 guests
cron
