It is currently Sun Jul 27, 2025 9:41 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 15, 2009 10:55 am
Last Name: Hodge
SniderMike wrote:
It's more funner that way.
Now you're talkin' my language Mike. :lol:
Bill Hodge
PostPosted: Wed Apr 15, 2009 11:39 am
I started out hammering frets, but now I press them in since I now use mostly stainless steel. SS fret ends love to pop out when using a hammer, not so when pressing.
Chuck
PostPosted: Wed Apr 15, 2009 12:23 pm
I now use a press which I made from an old Black and Decker thingy which converted your hand held drill into a drill press. It was a crappy idea but the mechanism in the system works great as a press. If you have one of those laying around from the 80's, then you're in business!
Under Compensated Nut!
PostPosted: Wed Apr 15, 2009 7:05 pm
I also fret my boards before I glue them to the neck. Here's my press inspired by Marios rig. It has 2 presses so you can fret from both ends and give one a chance to let the glue dry if you are gluing and it also gives a chance for the wood to relax around the fret some too. The radius caul is just a piece of a radius sanding block sandwiched between some alu. plates. You can also fret a guitar with the board on the neck if you have the correct neck caul. I was going to make a press simular the jaws II to slide along the rail that over hangs to the right but never got around to it .
PostPosted: Thu Apr 16, 2009 1:38 am
Last Name: Shaw
City: Philadelphia
I use a hammer like this. One head is nylon like this the other is hard red rubber like an eraser. I use the nylon face for fretting...
Users browsing this forum: Michaeldc and 19 guests
