It is currently Fri Jul 25, 2025 8:56 am
PostPosted: Sun Feb 08, 2009 9:22 pm
Being relatively new to woodwork and taking others advice I went out and bought a set of 3 water stones they were 220, 1000, 3000, and I've always been disappointed with their performance prefering toe old norton combination stone. I have some diamond files which work well and recently got a little falknivern dc3 which though tiny I now use almost exclusivley clamping the blade in the vice useing the diamond side first then the sapphire to finish and seldom strop at all now though if I do want a extra sharp edge have found autosol on a glass plate works well.
I've read about the scary sharp system and may try that and also may invest in some of these diamone whetstones then a 10000 grit spyderco ceramic stone
I'd be interested in any thought and sharpening tips you may share. One I've gained though slightly off topic I did a little woodcarving at adult ed and there was an old boy 96 who introduced me to scrapers and his main tool was just a piece of aluminium scraper size, when he died the family shared out his tools with the class and I now own that scraper, and it takes an edge easier for a noob than a standard scraper and I use it for a real course edge when I want to remove the wood when a plane tears out thanks to Frank there
Formerly JJH
PostPosted: Sun Feb 08, 2009 9:55 pm
I love the shapton ceramic stones on glass. They are the best I have ever used
http://shaptonstones.com/index.php?main ... th=164_166
PostPosted: Sun Feb 08, 2009 10:11 pm
I was set up with a Norton C/XC and 4000/6000 combo per Todd Stock's many suggestions here on the forum, then I sold them for a Work Sharp. Now I want them back :D
PostPosted: Sun Feb 08, 2009 10:18 pm
One vote for scary sharp using 3M finishing papers. Here's a link to a site run by a guy whose hobby seems to be sharpening things.
http://www3.telus.net/BrentBeach/Sharpen/
PostPosted: Sun Feb 08, 2009 10:19 pm
I like the takenoko 8000 grit stone from LMI or japan woodworker, that and a 1000 grit i forget what brand waterstone are about all i need.
I am lazy by choice, so i usually just use some sandpaper on glass and then finish up with the takenoko stone, or just the takenoko if the edge is not too beat up.
Jordan Aceto
Ithaca, NY
PostPosted: Mon Feb 09, 2009 12:43 am
First name: Heath
Last Name: Blair
City: Visalia
scary sharp is so cheap and easy. after that a quick strop on some leather with green jewelers rouge and im officially afraid of the edge i have produced. its that easy and its that sharp.
sweat the small stuff.
PostPosted: Mon Feb 09, 2009 7:36 am
Remembering that John is here in the UK, and that importing stuff from the USA is not a very sensible option at the moment I would suggest that this combination waterstone from Axminster would be your best option John. I have used one for a couple of years now and it has kept my chisels and planes are sharp as I could wish, and I'm very fussy about that!
http://www.axminster.co.uk/group_id//prodpage/2/product-King-Japanese-Combination-Waterstones-22468.htm#catprods
Also suggest you get one of these to go with it to keep the stones flat.
http://www.axminster.co.uk/product-Ice-Bear-Ice-Bear-Ceramic-Flattening-Stone-32262.htm
I use this holder that they have as well, but you can get away ith placing the stone on a cloth to prevent movement.
http://www.axminster.co.uk/product-Axminster-Non-Skid-Holder-20359.htm
PostPosted: Mon Feb 09, 2009 8:07 am
I use a combination of the "scary scarp" method (sandpaper on a piece of glass or a polished granite slab) and very fine Japanese waterstones.
PostPosted: Mon Feb 09, 2009 8:30 am
I have a 3 stage procedure that works for most situations: A belt sander to grind away nicks and to put a new bevel on an iron, a coarse DMT for common sharpening and a 8000 grit "King Gold" Japanese water stone. The iron or chisel stays in the Eclipse guide, if I want a secondary bevel I adjust it before honing.
Here's a link to Dick gmbh, which is where I got the stone http://www.dick.biz/dick/product/711004/detail.jsf
Here's my stone holder, made of some oily, dense wood which doesn't change dimensions much even in contact with the soggy waterstone (I have a second half that I use as a lid when I put it in my travel tool box). A second plywood "bench hook" holds the holder...
PostPosted: Mon Feb 09, 2009 9:41 am
John, The waterstone from Axminster that I mean is obviously the 1000/6000 combination, not the courser one.
PostPosted: Mon Feb 09, 2009 10:52 am
Last Name: Carpenter
City: Zigzag
State: OR
At first I too was disappointed with the edge I was getting on my combo waterstone. Once I made sure to start building up a nice slurry on the stone before use I love the edge I'm getting.
cheers! Bob
If brute force doesn't work you're not using enough of it!
PostPosted: Mon Feb 09, 2009 7:00 pm
I'm disappointed with waterstones too bob I'm glad it isn't just me as loads of people use them, and i have taken a side step that's worked for me next time I go to a friend, I'll ask for a lesson,
Formerly JJH
Users browsing this forum: doncaparker and 14 guests
