It is currently Fri Jul 25, 2025 8:49 pm
PostPosted: Sat Feb 07, 2009 11:45 pm
I am using an old grinder to take some steel off some blades. I have the 'standard' harbor freight router speed control used with heat blanket (from John Hall)
How do I figure out if I can use it on my old deck drill (40's Milwakee-looks like a looney toons drill) and the small grinder?
I'm getting old and cautious I guess....I want to use the drill for a strope machine with leather wheel. but 2000 +RPM is a bit much... :?
"Moving the ball forward!"
PostPosted: Sat Feb 07, 2009 11:58 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
As long as none of the smoke escapes feel free to use it, but remember electrical devices need the smoke inside to function. l
Check the amp rating of the tools and if they are less than 9 or 10 amps you should not burn out the controller, but remember the grinder will run hotter and have less power.
Fred Tellier
PostPosted: Sun Feb 08, 2009 9:44 am
If the tool has a "brush" motor you can usually use the speed controller. As Fred said, don't use it if the motor pulls too many amps or for continuous duty.
PostPosted: Sun Feb 08, 2009 11:24 am
Ok, cool, should I put a fan on the controller to cool it off? Would that help? Thanks
PostPosted: Sun Feb 08, 2009 12:43 pm
Most hand tools have brushed motors but not all. Most bench top and floor mount tools have fixed stater/armature motors
Users browsing this forum: meddlingfool and 28 guests
