| Official Luthiers Forum! https://www.luthiersforum.com/forum/ |
| Its almost done (pics) https://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=11088 |
| Author: | James Orr [ Mon Feb 26, 2007 3:47 am ] |
| Post subject: | |
Hypothetically speaking. . .lets say your binding didn't cover the entire edge of some back braces because you stopped shaving them down once the back was ringing like a gong. . .what would you do???
| Author: | Richard_N [ Mon Feb 26, 2007 4:01 am ] |
| Post subject: | |
I'd probably try to get hold of some slightly taller binding material or else put some purfling under the binding - either way you could then (hypotheticaly) rout a little deeper. How mich deeper do you need to go to cover the braces ? Take this with a pinch of salt tho since I've only built one guitar. Looks good by the way |
| Author: | Don Williams [ Mon Feb 26, 2007 4:05 am ] |
| Post subject: | |
I agree...go for purflings. They'll look fantastic with that git anyway. Lookin' good! |
| Author: | Bruce Dickey [ Mon Feb 26, 2007 4:21 am ] |
| Post subject: | |
Go James Go!
| Author: | Alain Desforges [ Mon Feb 26, 2007 6:50 am ] |
| Post subject: | |
Right on James! Lookin' mighty fine!
| Author: | LarryH [ Mon Feb 26, 2007 8:01 am ] |
| Post subject: | |
I've got to build me small jumbo - or large - whatever that is it looks great. Did you figure our your binding situation? |
| Author: | Dave Rector [ Mon Feb 26, 2007 10:51 am ] |
| Post subject: | |
Looking good James! I agree with the others that a purfling line under the bindings would look best. Good luck with it! |
| Author: | nathan c [ Mon Feb 26, 2007 1:16 pm ] |
| Post subject: | |
Am I the only one that can't see the pic?
| Author: | peterm [ Mon Feb 26, 2007 1:29 pm ] |
| Post subject: | |
[QUOTE=nathan c] Am I the only one that can't see the pic? [/QUOTE]
nope.... same here!
| Author: | Andy Zimmerman [ Mon Feb 26, 2007 3:26 pm ] |
| Post subject: | |
Nice GEEETAR!!! Yep 0.9 bindings and as many purfling strips necessary to cover it up |
| Author: | James Orr [ Tue Feb 27, 2007 3:50 am ] |
| Post subject: | |
Thanks guys. My server was under a big load last night, so that may be why the pic wasn't loading. Thanks for the tips too! My bindings are a bit shorter than the average 1/ 4" at .2", and the two braces in the waste of the back have an extra .1" showing. Do you really think purfling would help that? |
| Author: | peterm [ Tue Feb 27, 2007 4:10 am ] |
| Post subject: | |
Go for the purflings, it will help cover the braces and spice up the look of the guitar. BTW, looks great thus far!
| Author: | Richard_N [ Tue Feb 27, 2007 6:05 am ] |
| Post subject: | |
[QUOTE=James Orr] Do you really think purfling would help that? [/QUOTE] Did you kep the offcut material fronm the sides ? If so (and its tall enough) then you ould use it as binding . With a thin purfling line it'd look cool, If not I don't know what the tallest binding material is thats available but you could allways buy a back and side set of say walnut and cut off a strip to make bindings . You couls then used whats left over to make your next guitar
| Author: | James Orr [ Fri Mar 02, 2007 10:31 am ] |
| Post subject: | |
Hey guys, I've figured it out! I believe Peter's idea about using offcuts would be the most invisible. Thankfully I have some scrap left, but just enough to cut small patches. I'm going to rout a small section away from the braces with my dremel to fill with small patches. I'm going to set the depth to the same depth of my binding because my binding channels are shallow enough not to reveal any lining. I'd rather see a small blemmish than a spruce binding end. |
