It is currently Thu Jul 17, 2025 9:07 pm
PostPosted: Sun Sep 15, 2024 4:13 pm
Does anybody have any experience with what tape, adhesive, and procedure you would use to repair it ?
PostPosted: Sun Sep 15, 2024 7:17 pm
Online
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
There’s a lot of pressure on that seam. Making a lasting repair is likely to be difficult. Replacement belts are available for most machines. Amazon has several for this machine.
If I were to attempt it, I might try gluing a strip of fabric across the seam. I wouldn’t expect the repair to hold up.
PostPosted: Mon Sep 16, 2024 10:16 am
OK - Thank You
PostPosted: Mon Sep 16, 2024 10:50 am
If you’re not dead set on repair, I would replace.
Any piece of wood you run through it is worth more than a replacement conveyor belt is, and could be ruined if the repair goes janky while you’re sanding it. To my mind, not worth the risk.
https://www.amazon.com/performax-16-32- ... veyor+belt
These users thanked the author meddlingfool for the post (total 2): Kbore (Thu Oct 03, 2024 12:27 am) • Michaeldc (Mon Sep 16, 2024 2:56 pm)
PostPosted: Mon Sep 16, 2024 5:01 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Supergrit in Pa. A good source.
https://www.supergrit.com/ryobi-1600-je ... 16-32.html
These users thanked the author Ken Lewis for the post: Kbore (Thu Sep 19, 2024 9:57 am)
PostPosted: Tue Sep 17, 2024 5:43 am
I'm assuming the seam uses a lap joint. I would try contact cement or rubber cement. Contact cement gives a stronger bond with some flexibility, while rubber cement is more flexible with a weaker bond. Eventually you will probably need a new belt.
These users thanked the author Clay S. for the post: Kbore (Tue Sep 17, 2024 11:01 am)
PostPosted: Fri Sep 20, 2024 1:27 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
This Barge All-Purpose TF Cement is the bomb.
https://a.co/d/0KVauhc
I would consider this a "permanent" cement.
I would think a very thin leather strip lap bonded (per @Clay S. ) to your belt with this cement would work for a very long time.
I've been making leather scabbards/ covers for my expensive chisels and dragon files and was stitching the edges with waxed cord. I found the cement alone was not reversable and no longer even stitch the sides. Remarkable bonds.....
Measure Twice,
Karl Borum
PostPosted: Fri Sep 20, 2024 1:56 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I wonder what the chances are of gluing it back together and having it end up being "square" enough to track properly. A replacement belt I bought several years ago turned out to be out of square and no matter how I adjusted the tension screws on the roller, it would not track properly.
These users thanked the author J De Rocher for the post: Kbore (Fri Sep 20, 2024 2:26 pm)
PostPosted: Fri Sep 20, 2024 5:53 pm
My thoughts exactly.
PostPosted: Fri Sep 20, 2024 5:55 pm
First name: Brad
Last Name: Combs
The one I have on mine now is a replacement and is the same way. I just gave up and it rides the rail on the right side. :D
PostPosted: Sat Sep 21, 2024 12:17 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I had the same problem with mine. After trying a couple of new belts that tracked to the right, I got new bushings for the rollers and crowned the drive roller with tape. It still did it. I finally located some of the jet ceramic blocks to protect the metal from getting a groove sanded in it, and sold the machine (I had located a used 22-44 OSC for a good price. It tracks straight.). I noticed there was a slight offset in the seam edge on both the belts, so if you see that on a new belt, send it back!
These users thanked the author CarlD for the post (total 2): Kbore (Sat Sep 21, 2024 5:44 pm) • bcombs510 (Sat Sep 21, 2024 5:00 pm)
PostPosted: Wed Oct 02, 2024 9:22 am
Dang, I wish I had seen this post earlier. I just bought a used Supermax 16-32 that came with a torn conveyor belt. The Amazon prices even shipped to Canada is way cheaper than what I paid. At least I got a pretty good deal on the Supermax.
These users thanked the author Anthony Z for the post (total 2): Kbore (Thu Oct 03, 2024 12:27 am) • meddlingfool (Wed Oct 02, 2024 9:37 am)
Users browsing this forum: bobgramann and 24 guests
