It is currently Mon Jul 28, 2025 7:27 pm
 Post subject: 12 string archtop
PostPosted: Mon Jun 05, 2017 9:33 pm
Last Name: gregory
City: belton
Zip/Postal Code: 29627
I have only built one arch top guitar (6 string)and am interested in building a 12 string acoustic. I think I want parallel braces . The one I have currently finished has dimensions (17in) and x bracing out of the Bedenetto book. I have limited knowledge other than the one I have completed. This one does not have a bright bass tone. Other than that I am happy with the way it turned out. I want a nice bright tone.
My question is what, if any, thickness are changed with the top & back and bracing for a 12 string arch top.
Is there any dimensional information on 12 sting arch tops out there ?
 Post subject: Re: 12 string archtop
PostPosted: Tue Jun 13, 2017 12:36 am
First name: Andrew
Last Name: Berry
To quote Alan Carruth:
Quote:
First: a twelve is carrying roughly twice the tension of a six, so you need to make the top about 25% thicker: the stiffness goes as the cube of the thickness, more or less, and 1.25^3 is almost 2.
That is where I plan to start.
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=28226
PostPosted: Tue Jun 13, 2017 10:20 am
First name: Freeman
Last Name: Keller
I'm not sure where Al got that "roughly twice the tension" - a quick look at the String Tension FAQ at UMGF shows that a six string with lights (12 - 54) is about 165 pounds, with mediums (13's) about 190. Twelve string string gauges are typically a little smaller than those on a six - "lights" are usually 10 - 47 and at concert are around 260 pounds. Add the fact that many of us tune a 12 string down one or two semi tones and the tension, according to the FAQ, drops to 230 or even 210.
http://theunofficialmartinguitarforum.y ... UAAT2jyuUl
Therefore I like to think that, depending on strings, scale length and tuning, a 12 string will be approximately 150 percent of a sixer, not twice.
I've built two 12 strings and own and work on others. However since my experience is with X and ladder braced flat tops I don't feel qualified to comment on an archtop, other than to suggest actually doing the calcs with the specifications you plan to use.
Users browsing this forum: Chris Ensor and 15 guests
