It is currently Fri Jul 25, 2025 9:53 pm
 Post subject: Cantilevered Fingerboard
PostPosted: Mon Jun 05, 2017 1:53 pm
First name: George
City: Seattle
Anyone have thoughts to share, or maybe plans or a tutorial for doing a cantilevered fingerboard? I've been studying the info on Tom Bills' website, which is excellent and quite helpful, but I like to look at things from multiple angles (pun intended) before trying a new procedure.
George :-)
PostPosted: Mon Jun 05, 2017 5:37 pm
The Bills guitars are elevated fretboard rather than cantilevered, the extension is still supported on the upper bout.
Is that what you want to do? or do you want to be free floating? I do free floating myself.
PostPosted: Mon Jun 05, 2017 6:46 pm
First name: George
City: Seattle
Jeff,
Thanks for your response. I definitely need help, as I even need to learn the difference between the two! :-) Help finding a resource explaining either approach would be greatly appreciated.
Thanks again,
George :-)
These users thanked the author George L for the post: turkswork (Tue Jun 06, 2017 6:35 am)
PostPosted: Mon Jun 05, 2017 9:05 pm
As far as I can tell, Bills is basically standard archtop practice applied to the flat top with the support for the fretboard extension added to the neck with a short lap joint. This added extension is then carefully fitted and glued to the soundboard.
A cantilever extension, has a gap between it and the soundboard and so the joint (if any) at the body neck junction must be stronger and stiffer to allow it to hang free.
This can also allow for neck angle adjustment.... search "Stauffer guitars"
PostPosted: Mon Jun 05, 2017 10:26 pm
First name: George
City: Seattle
Gotcha! Thanks again. I'll be try that search.
George :-)
PostPosted: Tue Jun 06, 2017 10:39 pm
Last Name: Baley
City: Goleta
Zip/Postal Code: 93117
I think McPherson guitars also have a cantilevered neck. Check out their web page.
PostPosted: Wed Jun 07, 2017 1:04 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Yep Tom does standard archtop for necks/ fingerboard. This is what we did in the Moll shop
