Official Luthiers Forum! https://www.luthiersforum.com/forum/ |
Gang saw time - 25" and 25.5" https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=48175 |
Author: | MattEich [ Thu Aug 25, 2016 7:56 am ] |
Post subject: | Gang saw time - 25" and 25.5" |
Time for a fret slotting gang saw. A 25.5 board can be cut on a 34" scale saw, but from my figuring a 25" cannot be. Two different arbors, correct? Thanks all, Matt |
Author: | Tim Mullin [ Thu Aug 25, 2016 10:24 am ] |
Post subject: | Re: Gang saw time - 25" and 25.5" |
Correct. http://www.mullinguitars.com/calculating-guitar-fret-spacing-fingerboard-dimensions-and-string-setback.html |
Author: | printer2 [ Thu Aug 25, 2016 7:02 pm ] |
I get the file is password protected, mind you using Microsoft Works. |
Author: | Tim Mullin [ Fri Aug 26, 2016 11:23 am ] |
printer2 wrote: I get the file is password protected, mind you using Microsoft Works. Sorry you had trouble with this Fred. Many folks have used the spreadsheet zipped at this link, but I don't know if anyone has used Works. The Excel workbook itself is not protected, but there are cells in the worksheet that are capable of having protection turned on -- basically all cells with the exception of user-input cells in blue. The cell protection currently has no password protection, so if you're asked for one, I suggest simply pressing "enter", but this really should only happen if you try to modify a non-blue cell. Maybe someone else with Works can verify. The purpose of pointing to the spreadsheet was as a tool to verify the OP's conclusion. Where he only requires the fret spacing for different scale lengths, the Stewmac online calculator can of course do the same thing. |
