It is currently Wed Aug 13, 2025 6:40 am
 Post subject: Help with brace.
PostPosted: Sun May 22, 2016 10:12 am
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
So I've been struggling with how to make and replace a broken brace.
I don't have much of a power tool selection so I've been craving it completely by hand with a chisel, and sandpaper. I can make it look great but the struggle is coming from the fact that the back has a radius.
Can someone give me some guidance as to how to get the bottom of the brace to seat properly?
Thanks in advance.
 Post subject: Re: Help with brace.
PostPosted: Sun May 22, 2016 10:39 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Put a matching radius on the brace bottom. You can use a profile copy gauge either on the inside or out of the guitar depending on your ability to get the tool in the guitar. Transfer the radius to a cardboard template, cut it out and then transfer it to your brace. You can use a plane to shape the bottom of the brace. When finished it should be close enough to seat properly. You can fine adjust with sand paper.
PostPosted: Sun May 22, 2016 12:18 pm
State: Tennessee
Scribe a line, take a short piece of a pencil flatten/thin it so your point just touches the high spot on the new brace and draw your line. A sharp block plane and two ,three minutes later you have a perfectly fit brace. Good Luck
PostPosted: Sun May 22, 2016 3:53 pm
Last Name: Cox
Chalk fit it.
Rub a little powdered artists chalk on the brace. When you rub it on its matching spot - it will leave a mark on the chalk. Plane that spot. Repeat till you have an even fit. You want a chalk color that's easy to clean up and doesn't have any dye in it that would get into the wood... I think I would choose white....
These users thanked the author truckjohn for the post: ChuckH (Thu May 26, 2016 10:10 pm)
PostPosted: Thu May 26, 2016 10:12 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I agree with Truckjohn. Get the brace close to radius then chalk fit the brace. Use small plane and scrapper to fit perfect.
Sent from my iPad using smoke signals
Users browsing this forum: doncaparker and 28 guests
