https://www.luthiersforum.com/forum/
finish gun pressure?
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=45888
Author:  alan stassforth [ Mon Jun 15, 2015 2:31 pm ]
Post subject:  finish gun pressure?
Just curious as to what pressure I should be running my gun at.
I have an old Binks touch up gun, and usually set the copressor to 25-30 lbs.
I recently bought a Finex gravity feed hvlp gun,
and am trying to dial in the pressure, and had some new thoughts.
Should I have a gauge at the gun, and go with the pressure as the gun is operating?
I have been shooting shellac at a 1 1/2 lb cut.
I want to get better results, so I don't have to do so much sanding at the end.
Any advise would be appreciated.
Alan
Author:  Glen H [ Mon Jun 15, 2015 4:37 pm ]
Post subject:  Re: finish gun pressure?
I pretty much ignore my gauge. I just hold the trigger down and increase the pressure until I get good atomization and pattern. Obviously, I start with the air flow control screw on the gun at stopped. Too much pressure and you're just blowing finish all over the place. Just takes a couple seconds and a couple trigger pulls. This works for me.
Author:  alan stassforth [ Mon Jun 15, 2015 5:59 pm ]
Thanks Glen.
That's pretty much what I do.
Alan
Author:  B. Howard [ Tue Jun 16, 2015 7:37 am ]
I run a regulator right at my gun. static feed pressure is usually around 80psi, constant flow pressure is around 25-30 psi. Here is a link to an article i did a little while ago on setting up a spray gun and proper use.
http://howardguitars.blogspot.com/2015/ ... brian.html
Author:  alan stassforth [ Tue Jun 16, 2015 11:32 am ]
You rock, Brian!
Exactly what I needed to read.
I'll give that a go, today!
Last coat on an instrument called a phin,
pronounced pin.
Alan
