Official Luthiers Forum! https://www.luthiersforum.com/forum/ |
Bending purfling? https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=45874 |
Author: | Cablepuller [ Fri Jun 12, 2015 1:47 pm ] |
Post subject: | Bending purfling? |
Hi Having recently had to add a larger binding channel due to a router accident i am now going to add purfling under the binding on the sides This will mean the purfling will have to be curved sideways I was wondering whether it will bend ok on an iron sideways without unglueing the 2 parts of the binding or should it be done separately ..is a steamer better for this? (Its wood purfling by the way) And any other tips please on making this a stress free process Thankyou |
Author: | jack [ Fri Jun 12, 2015 2:00 pm ] |
Post subject: | Re: Bending purfling? |
if you're using wooden binding, glue the binding to the purfling first, then bend the glued binding/purfling combination as if you were bending just the binding.. |
Author: | Clinchriver [ Fri Jun 12, 2015 4:12 pm ] |
Bends good ![]() |
Author: | Phil J [ Sat Jun 13, 2015 6:55 pm ] |
What kind of glue do you use to glue the purfling to the binding? I am thinking of doing this on an upcoming build but was afraid the purfling would come unglued during the bending process. |
Author: | Cablepuller [ Sun Jun 14, 2015 4:36 am ] |
Phil J wrote: What kind of glue do you use to glue the purfling to the binding? I am thinking of doing this on an upcoming build but was afraid the purfling would come unglued during the bending process. I use titebond phil |
Author: | Clinchriver [ Sun Jun 14, 2015 5:25 am ] |
Phil J wrote: What kind of glue do you use to glue the purfling to the binding? I am thinking of doing this on an upcoming build but was afraid the purfling would come unglued during the bending process. My sole use for titebond lll it takes the heat so to speak. |
Author: | Phil J [ Sun Jun 14, 2015 3:28 pm ] |
I'll pick up some Titebond 3 and give it a try then! Thanks! |
Author: | Mike OMelia [ Sun Jun 14, 2015 4:48 pm ] |
I have been reconsidering this approach, mainly because of tight bends. But, I'll admit I don't have any good ideas. Too many times I've had bad luck in the tight turn areas. So, if there are other ideas, I'm listening. |
