It is currently Fri Aug 15, 2025 12:10 pm
PostPosted: Mon Jun 08, 2015 10:58 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have a great looking walnut set that I am building a 00 guitar. The sides for this set came in about 5 mm narrower than I would have wanted. They are almost wide enough that if everything went perfect while bending and profiling they would be OK. My thought is to do my best and then have the end blocks proud, such that when I profile the rims before gluing on the linings the rims maybe a bit narrow at the deepest part of the waste and the end block. I would then glue on the linings tall enough so that they could be profiled to the correct radius and diminsions. There probably will be areas where the sides are a couple of mm below the top of the linings.
I do not see any issues, as I would route this off for the bindings anyway, but I thought I would put it out as I have never ran into this issue before.
Any thoughts.
PostPosted: Mon Jun 08, 2015 11:12 am
First name: Tom
Last Name: West
State: Nova Scotia
John: Have never done this also but a nice learning opportunity and I bet it would work out super.
Tom
These users thanked the author Tom West for the post: johnparchem (Mon Jun 08, 2015 11:58 am)
PostPosted: Mon Jun 08, 2015 11:28 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Yes, it can be done that way. I've done it once or twice, and recommended it whenever you need another 1/4" or so.
These users thanked the author Rodger Knox for the post: johnparchem (Mon Jun 08, 2015 11:58 am)
PostPosted: Mon Jun 08, 2015 11:45 am
I've also done it on one set. Hardest part was just to make sure I didn't waste any of the width with poor setup/measuring.
These users thanked the author SteveSmith for the post: johnparchem (Mon Jun 08, 2015 11:58 am)
PostPosted: Mon Jun 08, 2015 3:39 pm
"Yes, it can be done that way. I've done it once or twice, and recommended it whenever you need another 1/4" or so."
Ditto
These users thanked the author Clay S. for the post: johnparchem (Mon Jun 08, 2015 8:28 pm)
PostPosted: Mon Jun 08, 2015 7:30 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
John, I haven't done this, but I've seen it recommended in many posts. I can't see a difference between that and gluing to full width sides, then machining those sides away for the binding! When I route for bindings, I always go totally through the sides to the lining,
These users thanked the author Imbler for the post: johnparchem (Mon Jun 08, 2015 8:28 pm)
PostPosted: Mon Jun 08, 2015 8:27 pm
Last Name: Parchem
City: Seattle
State: Wa
Thanks all,
I can go at it with a bit more confidence.
PostPosted: Tue Jun 09, 2015 9:07 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What they say, works just fine.
Bryan Bear PMoMC
Users browsing this forum: jfrench, Powdrell1 and 16 guests
cron
