It is currently Fri Aug 15, 2025 4:30 am
PostPosted: Thu Feb 12, 2015 12:59 pm
Been thinking it might knock a few minutes off the job.
The instructions say to leave braces a 1/4" high, which seems very wasteful, both in materials and the time required to make a second cut getting the height trimmed.
Anybody rocking said device?
PostPosted: Thu Feb 12, 2015 2:47 pm
The Luthier Tools thingamajig? I have one. I don't leave them that proud. The top of my brace is just proud of the jig in the center. I don't want to shave that much down, but more importantly, I want my X-brace joint perfectly centered in each arm.
PostPosted: Thu Feb 12, 2015 3:03 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Yes. It works great. Probably one of the biggest time savers I've invested in my shop. Just put the brace in the jig and rip it on the table saw. boom. done. next brace. boom. done. etc...
Link:
http://www.luthiersuppliers.com/products/p6.html
PostPosted: Thu Feb 12, 2015 3:47 pm
I use one and do it the same as Gil.
Press the brace in and with my table saw set up, I just rip the excess off.
PostPosted: Thu Feb 12, 2015 4:01 pm
Ok, I'll bite...
PostPosted: Thu Feb 12, 2015 4:13 pm
Last Name: Beaver
City: Lake Forest
I also use the brace maker from Luther supplies, the sponsor here. It works excellent.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Feb 12, 2015 4:28 pm
State: Tennessee
I have one and it works. But then I always hit the gluing surface with a sharp block plane, I made a little jig (shooting board) and its just as fast and more fun to shape them with the block plane :mrgreen:
And if you build traditional Martin style guitars the shooting board will handle the 3/4 back braces easily.
PostPosted: Thu Feb 12, 2015 4:30 pm
Plane or jointer will be my preference...
PostPosted: Thu Feb 12, 2015 4:55 pm
I think this is original DIY brace contour gadget
http://liutaiomottola.com/Tools/BraceArchJig.htm
Ken Cierp
These users thanked the author kencierp for the post: unkabob (Thu Feb 12, 2015 9:37 pm)
PostPosted: Thu Feb 12, 2015 6:11 pm
Sorry, Luthier Suppliers. I got the name wrong. Blame it on Chipotle.
PostPosted: Fri Feb 13, 2015 8:05 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
A little something for those of you with OCD (or worse, CDO where the letters are in alphabetical order). When you bend a batten around 3 points you don't get a consistent curve - it has flat spots near the end. Here is how to easily solve this and the article mentioned has the proper offsets for common radii:
https://www.flickr.com/photos/ruby1638/ ... 172644427/
As usual with Flickr, hold your mouse on the text below the title and you will see any description that is there. Then click on any picture to start the sequence from that point.
Ed
PostPosted: Fri Feb 13, 2015 8:49 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Ive never had problems with the arc being flat at the edges of the bracemaker jig. It's usually right on, or if slightly off I just give it a few strokes on the radius dish with sandpaper.
PostPosted: Fri Feb 13, 2015 2:18 pm
Well for better or worse I pulled the trigger. We'll see what the results are...
PostPosted: Sun Feb 15, 2015 11:01 am
First name: Tracy
Last Name: Leveque
State: CO
Thanks for all the good comments! You are forgiven James, I love Chipotle too! After selling these jigs since 2005, I've only had a few complaints. The original jig was designed by Dana Bourgeois, and John Mayes modified it, then we worked with John to modify it even more. Hope you enjoy it!
PostPosted: Sun Feb 15, 2015 5:01 pm
Me too! If it even takes off ten minutes, it's worth it...
PostPosted: Wed Feb 18, 2015 7:23 am
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
Here's my brace maker:
And the accompanying blog entry: http://glennaycockwoodworking.blogspot. ... pound.html
PostPosted: Wed Feb 18, 2015 9:30 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
I just clamp my brace over the edge of an exactly radiused piece of plywood and then use a pattern router bit against the plywood to rout of the overhanging brace material which puts the exact radius on the bottom of the brace.
PostPosted: Wed Feb 18, 2015 10:12 pm
I did that for a while, in fact spent a great deal of time making router table brace shaping jigs, but I got too much chatter on the bottom of the braces.
PostPosted: Mon Mar 09, 2015 3:36 pm
Well well, works a treat! This is one of those things that I obviously should have had yeas ago!Image
