Official Luthiers Forum! https://www.luthiersforum.com/forum/ |
How do you calculate the center of the sound hole https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=44053 |
Author: | Siebrasse [ Thu Aug 28, 2014 1:22 am ] |
Post subject: | How do you calculate the center of the sound hole |
Hi Guys, I'm making the workboard by the instruction from the book Guitarmaking by Cumpiano. I can not figure out how to calculate where the center of the sound hole comes. I'm making a steel string Grand Auditorium Model. Any help on this is appreciate. |
Author: | DennisK [ Thu Aug 28, 2014 1:43 am ] |
Post subject: | Re: How do you calculate the center of the sound hole |
Decide where you want the top edge of it in relation to the fingerboard end, and put the center half the diameter down from there. No set rules on the fingerboard relation. Classicals usually have it around half way between the 18th and split 19th frets. Steel strings, anything goes. I tend to prefer the soundhole up high, with the fingerboard end length on the short side. Some people have large expanses of fingerboard wood past the last fret, or a space between the fingerboard end and the soundhole. Here's one where I put the soundhole edge under the 19th fret, with a very short fingerboard end overhanging the soundhole. Hopefully the short end length won't result in chipping if that last fret ever has to be pulled... Attachment: FrontBody.jpg
Author: | dnf777 [ Thu Aug 28, 2014 3:56 am ] |
Off topic, but that is THE COOLEST rosette in the history of guitar-making, Dennis!! |
Author: | jfmckenna [ Thu Aug 28, 2014 7:26 am ] |
Red on black, venom lack; Red on yellow, killer fellow. |
Author: | Trevor Gore [ Thu Aug 28, 2014 8:11 am ] |
....errr...Red-bellied black snake? |
Author: | TonyKarol [ Thu Aug 28, 2014 12:51 pm ] |
Most 14 fret necked guitars have a sound hole centred at 5 7/8 or 6 inches, from the top of the body where the neck joins (ie, the 14th fret !!!), on the centreline |
Author: | jfmckenna [ Thu Aug 28, 2014 5:00 pm ] |
Trevor Gore wrote: ....errr...Red-bellied black snake? I was thinking a coral snake: https://www.google.nl/?gws_rd=cr&ei=Oab ... oral+snake |
Author: | Trevor Gore [ Thu Aug 28, 2014 6:37 pm ] |
...still sounds fairly nasty! I was working in the tool shed the other day and saw the tail of a diamond python just about to disappear under the eaves into the roof of the house. I grabbed it and started pulling.... 10 feet later.... Back on topic, the center of the sound holes normally turns out to be pretty close to 6" from the top edge of the upper bout. If you don't get an answer close to 6", have a long think about things and make sure you got your sums right. And yes, Dennis, nice rosette! |
Author: | Quine [ Fri Aug 29, 2014 10:39 am ] |
The upper part of the X braces are usually pass around 3/8" from the edge of the sound hole. Pencil out where your X braces will be and where the finger board will end. Then you can cut out a paper circle that's your sound hole dia. and position it where it looks right to you. The braces are the only really fixed point for the position. The fingerboard is pretty much up to your taste for how close it is to the sound hole. |
Author: | TonyKarol [ Fri Aug 29, 2014 12:02 pm ] |
When I design a bracing pattern, I start with knowing where the end of the FB is, the scale length and where the bridge will go, and its size, draw in the soundhole .. the X brace is then figured out and positioned from there ... using its angle, the edge of the soundhole, and the bridge wings ... |
Author: | jfmckenna [ Fri Aug 29, 2014 2:52 pm ] |
Trevor Gore wrote: ...still sounds fairly nasty! I was working in the tool shed the other day and saw the tail of a diamond python just about to disappear under the eaves into the roof of the house. I grabbed it and started pulling.... 10 feet later.... Back on topic, the center of the sound holes normally turns out to be pretty close to 6" from the top edge of the upper bout. If you don't get an answer close to 6", have a long think about things and make sure you got your sums right. And yes, Dennis, nice rosette! Yikes! LOL I'm not sure Australia was meant to be inhabited by simians. Well on the bright side I'm sure you have rats or mice anywhere near your house. --- I've always just based the sound hole location from the end of the fretboard but mostly I just make sure they are at least close to some of the more traditional plans I have. |
Author: | fingerstyle1978 [ Fri Aug 29, 2014 3:23 pm ] |
My method is simple. First I throw darts at the soundboard and I pick the one that looks like the best location. Then I bust out my sawzall for some precision cutting and hammer that thing out. LOL, I do not recommend this method... |
Author: | TonyKarol [ Fri Aug 29, 2014 4:26 pm ] |
Trevor ... 10 feet later .. Dinner !!!! Just not sure for who !!!! |
Author: | JimO [ Mon Sep 01, 2014 10:39 am ] |
About like my pet moccasin down here at the raw water pumping station. He jumps into the water for joy whenever I go down there, LOL. About as big around as my arm. Like to sun on the concrete. I just make a lot of racket to let him know I'm coming. |
Author: | Tom West [ Mon Sep 01, 2014 8:08 pm ] |
Edwin: For a 4" soundhole measure 2" from the edge perpendicular to the diameter and you will have the center ![]() Tom |
