https://www.luthiersforum.com/forum/
Guitalele
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=44020
Author:  aqualibguitars [ Sat Aug 23, 2014 8:58 am ]
Post subject:  Guitalele
Hello friends
i hope all of you are doing fine
one of my friend want me to build guitalele with steel strings for him.
i tried to find on internet but not found.
may i know where i will get.
and what is the length and width of the body.
Also i have autocad plans for classical guitar so if i dont find the plan on internet
to what scale should i print the plan to get the dimensions of guitalele
Thanks in advance
Author:  Clay S. [ Sat Aug 23, 2014 10:03 am ]
Post subject:  Re: Guitalele
The guitalele sounds like it is a terz or quint guitar by another name. I seen it described as a baritone body with a six string neck. That might be a good starting point for your design.
Author:  JasonM [ Sat Aug 23, 2014 4:52 pm ]
I've built a few like what you are describing, but they are 6 string. I called them soprano's, and they have a 17" scale lengh. Any smaller, and they would not be playable for an adult. If you have autocad, just scale down your design until the scale length is 17", with the exception of the neck and bridge. leave the nut full width, as if it were a dread, and scale the bridge up a bit to keep a large enough footprint to stay glued down. Also, you will tune it up to at least A, and preferably B, if it will take it, to get proper string tension.
If you have a paper plan, you could even use a photocopier to reduce it. Somewhere between 33% - 45% should get you in the range for a17" scale length.
Soprano Guitar - McGillivray Guitars: http://youtu.be/Ov0d1VjpDhg
Author:  aqualibguitars [ Wed Aug 27, 2014 7:59 am ]
Hello friends thanks for ur advice
can i know what will be thickness of the top?
and the dimensions of the bracings
Author:  PeterF [ Wed Aug 27, 2014 2:53 pm ]
I made a 3/4 size guitar for the challenge last year, which is sort of like a guitalele but slightly bigger. It's tuned up 4 semitones compared to a standard guitar. I can't remember offhand what the scale length was. You can see it here viewtopic.php?f=10134&t=38819
I think I did the top about 2mm thick but it was piranna pine which is less stiff than spruce. It has got quite belly on it now after a year. I braced it fairly lightly with a normal x brace and 3 fan braces instead of tone bars. It also had carbon butress braces though, so that would have made it a bit stiffer.
If you are interested I can send you the autocad plans I drew for it.
Author:  JasonM [ Thu Aug 28, 2014 6:24 pm ]
.100 for the top should get you close, and keep the braces .250 wide for a good glueing surface, but take the height down by half or a little more, from a "full" sized guitar. This will get you a sturdy enough first one, but you will have to refine from there as you learn. Can't really give precise numbers without knowing your building materials.
Author:  aqualibguitars [ Fri Aug 29, 2014 8:48 am ]
i will be using sitka spruce top.
Author:  Michael.N. [ Fri Aug 29, 2014 9:50 am ]
I use just 3 small fan braces for a Guitatlele size model. Near 2 mm thick on the soundboard. It's a very small model with the Bridge itself providing a lot of stiffness. It's very easy to over build such an instrument, unless you want a more typical Ukulele type tone. In which case a stiffer top might be better.
Author:  David LaPlante [ Fri Aug 29, 2014 11:18 am ]
Here's one I made for my wife (the lead singer in our trio).
Body is the same size as a Martin Tiple though not as deep. Scale also the same as the tiple (17"+?).
Made for steel strings with an "X" brace and pin bridge. Tuning is two and a half steps up (5 frets) and strung Nashville style.
Author:  aqualibguitars [ Sat Sep 06, 2014 8:54 am ]
Thanks sir for ur advice
if we tune 4 semitones higher . the strings wont break?
Author:  PeterF [ Sat Sep 06, 2014 11:12 am ]
No because the scale is shorter. Imagine putting a capo on a normal guitar - the tension stays more or less the same, but the pitch rises. It's the same with this, only instead of using a capo, you just move the nut and the whole end of the neck closer to the body.
Author:  aqualibguitars [ Wed Sep 10, 2014 1:22 pm ]
thnks sir.
i was afraid of breaking it
