It is currently Sun Aug 17, 2025 9:27 am
PostPosted: Sat Jul 26, 2014 8:19 am
Good Morning Y'all...
I'm building some cutaways off the OLF plans. The cutaway radius is somewhat tighter on the horns than my other cutaway model. I'm wondering how thin you take your sides down in the cutaway area?
I normally build larger mahogany guitars at around .085, but I'm thinking that due to all the structural strength the curves will give that I could probably run it partway through the drum sander to just past the horn down to .075 or possibly even .070 and feather in the transition to making bending happen without any compression lines. Same for rosewood.
So, how low do you go?
PostPosted: Sat Jul 26, 2014 8:25 am
I do all my sides at .075 you can go to .070 just remember that your do need some sanding room. The key here is the bending technique. Keep the cutaway well damp till you get there to bend
PostPosted: Sat Jul 26, 2014 9:47 am
Thanks John...
PostPosted: Sat Jul 26, 2014 11:31 am
I have been doing double sides on my cutaways and archtops. That almost eliminates breakage. Otherwise I'm around .070 on a solid side.
PostPosted: Sat Jul 26, 2014 1:02 pm
Wow. You guys at definitely thinner ha I normally go..l
PostPosted: Sat Jul 26, 2014 2:34 pm
I meant for the cutaway. .080 otherwise
PostPosted: Sat Jul 26, 2014 7:21 pm
Ah...
Well, I took the sides to .075, then ran the first foot of the cutaway side through to .070, then stopped and feathered in the two heights. We'll see if I win or not...
PostPosted: Sat Jul 26, 2014 7:50 pm
Whaddya know, it worked!ImageImage
PostPosted: Sun Jul 27, 2014 2:18 pm
First name: Dan
Last Name: DeBruler
Yep! It worked.
Why save the best for last when you can give it today.
Love. Reach. Teach
PostPosted: Sun Jul 27, 2014 2:20 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Good for you my friend.
PostPosted: Sun Jul 27, 2014 2:27 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Looks spot on!
PostPosted: Sun Jul 27, 2014 2:31 pm
Yeah, the whole shape conformed to the mold within a few millimetres. Well pleased. This is also the first time I've used an insert in the mold for the cutaway, and it is surprisingly helpful.
PostPosted: Sun Jul 27, 2014 11:30 pm
First name: Heath
Last Name: Blair
City: Visalia
John, do you use water when bending all mahogany or just the cutaway portion? I've had better luck bending mahogany dry. Just curious about your technique. Thanks in advance.
sweat the small stuff.
PostPosted: Mon Jul 28, 2014 3:03 pm
So far so good!Image
PostPosted: Mon Jul 28, 2014 11:05 pm
That looks great!
PostPosted: Mon Jul 28, 2014 11:10 pm
Why thank you!
The cutaway was drawn out by mishmashing the OLF MJ and SJ shapes together, and a lot of looking for the exact right size roll of tape and glue bottle to trace around. There must be a formula....
PostPosted: Tue Jul 29, 2014 10:31 am
I use a little water just enough for damp heat not steamy.
PostPosted: Tue Jul 29, 2014 11:40 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I'm a little late in here, but I have gone much thinner on sides, as thin as .06" for the whole side. That was once with bloodwood, and once with mesquite. I'd say .07" should be good for mahogany, but I wouldn't hesitate to go thinner if the piece was difficult to bend. Mahogany usually bends easily, but I've read there's some out there that doesn't like to bend.
PostPosted: Tue Jul 29, 2014 11:45 am
I've definitely seen my fair share of mahogany that just wouldn't bend. We' re recently had a batch of Padauk that would just shatter and rupture with just a bit of pressure. Some woods just won't.
I'm considering double sides for cutaways. To me, .070 feels too thin for my liking. In fact, I prefer heavier stiffer sides. Especially on big 16 1/4 guitars like this one. I feel like flimsy sides can lead to a mushy bass response...
