https://www.luthiersforum.com/forum/
Cam Clamps slipping?
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=43735
Author:  powdrell [ Sun Jun 29, 2014 7:12 pm ]
Post subject:  Cam Clamps slipping?
Got a coupla cam clamps that are slipping...they have worked quite well until this month....Basically, after tightening clamp, it loosens over a 60 second period....gotta fix or replace. Would rather fix.
-Wood is not cracked,
-no oils on the steel bar,
-cam bar is good
-back of steel is getting shiny....do I need to re-groove the back edge? Re-file grooves?
any ideas for fix? Thanks.
Author:  Mike Collins [ Mon Jun 30, 2014 1:46 pm ]
Post subject:  Re: Cam Clamps slipping?
the most important thing to remember when using
cam clamps are to -position it-Bring the bottom & top pieces
to the joint-Then hold the bottom & top (wooden parts) tight at the back
just behind the steel bar -then adjust the cam .
Practice this with non -important pieces.
Author:  Lonnie J Barber [ Mon Jun 30, 2014 2:12 pm ]
I don't have any cam clamps. But there is a thing on the internet that shows how to make your own. I would like to have some.
Author:  enricopg [ Wed Jul 02, 2014 12:58 am ]
The same happened to me. I own about 15 cam clamps. Two of them showed the same problem you are having. It has nothing to do with how you clamp them. I am pretty sure they are broken. Either you try to fix them (you have to figure out how), or you throw them away. I still have them, but I don't use them anymore. It is too dangerous. I also wrote to klemsia but received no answer. Sorry I could not help.
Author:  Colin North [ Wed Jul 02, 2014 5:07 am ]
If the grooves have worn smooth you could try a re-file.
Are they Klemsia or another brand?
I have about 30 Klemsia clamps and haven't had any problem at all with them over the years.
Author:  Tim Mullin [ Wed Jul 02, 2014 9:04 am ]
The cam relies on wood-to-wood friction. If those surfaces become contaminated, the cam can slip. I disassembled one of mine, a few swipes with 120 grit and a splash of naphtha. Reassembled, problem solved. YMMV
Author:  powdrell [ Wed Jul 02, 2014 2:08 pm ]
Klemmsia clamps are still working.....these are a different 'brand'.....I'll try cleaning/roughing up back edge.....thanks.
