It is currently Mon Aug 18, 2025 9:09 pm
 Post subject: New tool
PostPosted: Tue May 20, 2014 12:14 pm
Just received a purfling and binding cutter from China through Ebay. Cost $33 incl postage.
Fitted with double cutters, (+ 2 spare under the bottom screw) - intended for violin purlings. They would need a bit of work as they are double bevelled.
Solid brass, 100 mm long (4") overall, pretty hefty at 210 grammes (nearly 8 oz).
The Schneider Gramil blade is for comparison.
Was not sure if it was useable as supplied or could be modified easily to use for guitar binding and purfling ledges.
Looks like I'll have to drill another through hole at 90 degrees to the existing one to get a cut opposite the flat, as well as the curved, side.
If I want to use the hock blade, I'll have to enlarge the blade holding mortice a bit and it should be ready to go - needs widened by 1.5 mm (1/16")
 Post subject: Re: New tool
PostPosted: Wed May 21, 2014 1:58 pm
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Turn the blades round and single bevel the new end to see how it goes, and maybe flatten the points on the d/bevels so you don't slice your fingers.
PostPosted: Wed May 21, 2014 3:25 pm
Smart thinking Batman! Good idea, especially blunting the point. No good watching the sharp end when another one can come up and bites you in the backside as it were.
Thanks Kamusur / Steve.
PostPosted: Wed May 21, 2014 5:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Where's the motor?
Nice item ya got there!
PostPosted: Thu May 22, 2014 12:20 am
Mike O'Melia wrote:
Where's the motor?
Motor for the gramil? - See top picture. :)
PostPosted: Mon May 26, 2014 2:59 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I bought one of those from international luthiers supply in 1989. Never did figure how to operate it as the blades were for cutting channels for violin purflings. Unfortunately the channel it cut was way to wide to fit the purfling. I just put it aside. It's around here somewhere. Maybe I'll get it out and just look at it. Lol
Users browsing this forum: DennisK and 21 guests
