It is currently Mon Aug 18, 2025 11:00 pm
 Post subject: string height off top
PostPosted: Sun May 18, 2014 9:37 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
I have read many times, Im a hobby builder uh builder is probably too strong, there is to be 1/8" saddle sticking out of a 3/8" thick bridge between the D and G strings . That makes the height of strings 1/2" off the top. Is that the consensus of opinion here?
PostPosted: Sun May 18, 2014 10:14 pm
Yup, that's the target...
PostPosted: Mon May 19, 2014 3:53 am
First name: Tom
Last Name: West
State: Nova Scotia
Also for me and I expect the action to be at the correct height with these figures.
Tom
PostPosted: Mon May 19, 2014 7:05 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I shoot for 7/16", wouldn't want to go over 1/2". My goal is 11/32" bridge with about .100" saddle.
Brian
PostPosted: Mon May 19, 2014 9:21 am
depends but 1/2 is target 9/16 is MAX 7/16 is min for me
On initial set up if you set up on 7/16 , you can expect the top to rise a bit . Also keep in mind that you have to have the RH controlled when setting the braces. RH can cause the top to rise. RH drop can lower the top
I glue braces at 40% RH in the shop.
If we are speaking of Martin specs
I want to see .125 saddle on a through bridge saddle slot and about .150 on a drop in.
PostPosted: Mon May 19, 2014 1:34 pm
Last Name: smith
City: hemet
State: ca
Of course you have to have your neck set in mind and the action you want when deciding what thickess you want the bridge. I dont see anyway to anticipate the possible rise of the top and get optimum action.
I guess I should have linked to an authority but I want to see opinions and why. The whys Ive read say you maximum sound without over-leveraging the bridge. Anyway the link below is an example but I want to see what the community says.
http://www.frets.com/FretsPages/Musicia ... angle.html
PostPosted: Mon May 19, 2014 5:12 pm
I'm with John for height off the soundboard.
I anticipate a rise in the top, depends on the wood and (maybe the size of lower bout I think)
Seems to be around 3/64 on average (about 0.7 mm), give or take - only 5 builds to far.
Bridge around 3/8", rest is saddle.
Users browsing this forum: Bing [Bot] and 35 guests
