https://www.luthiersforum.com/forum/
Gibson J35 Update Sound Link
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=42633
Author:  WudWerkr [ Tue Feb 04, 2014 2:09 pm ]
Post subject:  Gibson J35 Update Sound Link
Have a young Man who has brought me a Gibson J35 Acoustic Electric ... The Neck Is Twisted , and he says getting worse . I called Gibson , they wont sell me a Replacement neck . Any Suggestions ?
Author:  ZekeM [ Tue Feb 04, 2014 2:18 pm ]
Post subject:  Re: Gibson J35
Make a better one! bliss
Author:  WudWerkr [ Tue Feb 04, 2014 2:30 pm ]
Have to try and save Gibson Logo and if that doesnt work then what .
Author:  ZekeM [ Tue Feb 04, 2014 2:36 pm ]
Can you remove the entire front of the headstock and glue it on as the faceplate on a new neck?
Author:  WudWerkr [ Tue Feb 04, 2014 2:38 pm ]
Yeah probably . Was hoping for other options to avoid building a neck
Author:  ZekeM [ Tue Feb 04, 2014 2:38 pm ]
I'm sure someone else has a better way to address the twisting. I'm just throwing out ideas.
Author:  brazil66 [ Tue Feb 04, 2014 3:34 pm ]
You can play around with heat treatment. For the cost of pulling, making , installing and setting up a new neck.....he could just buy a new one for that. Apparently he's not the original owner.
Author:  WudWerkr [ Tue Feb 04, 2014 3:43 pm ]
Bought it second hand ... Has less than $400.00 in guitar as is
Author:  Clay S. [ Wed Feb 05, 2014 9:26 am ]
Do something like this:
http://www.bestbassgear.com/ebass/repai ... esign.html
Just because the neck is twisted doesn't mean the guitar has to be unplayable. Just fix the string paths. bliss
Author:  jmpbuffalo [ Wed Feb 05, 2014 9:38 am ]
If you want to preserve the originality of the instrument as much as possible, remove the fingerboard, plane the neck true, and re-install the fingerboard. I believe I saw something like that on Frank Ford's website. At that time you could also install neck reinforcement if you think it necessary.
Joe
Author:  WudWerkr [ Wed Feb 05, 2014 9:43 am ]
Joe
I have suggested this , The fella says its getting worse . I have to verify that , but if it is this would be only a Temp fix . idunno
Author:  WudWerkr [ Thu Feb 06, 2014 3:05 pm ]
Update , Looking down the neck from head stock , it does appear to have a slight twist . HOWEVER , when I did some checking with Parallel's its not twisted . The Bridge on the J35 is an angled bridge and the Saddle has been ground down on an angle as well " not factory " the whole thing creates an optical illusion . oops_sign
Because someone messed with the bridge the action above fret at 1st string is .040 and at 6th is . 058 and he wonders why it buzzes ... Also , whoever messed with it before loosened the truss rod nut to the point it was about to fall off ..... gaah New Saddle ordered ... Reset to proper string height and a little truss rod action and it should be in excellent shape. [:Y:]
Btw , where he had it worked on before was a "Reputable " Guitar store ... Sad
Author:  the Padma [ Thu Feb 06, 2014 3:15 pm ]
. [headinwall]
Author:  the Padma [ Thu Feb 06, 2014 3:16 pm ]
Loose nut eh! Could say sumptin...but ....
Author:  Alex Kleon [ Thu Feb 06, 2014 3:18 pm ]
You can say that again!
Alex
Author:  ZekeM [ Thu Feb 06, 2014 3:27 pm ]
Aahhhhh nuts!!!!Image
Author:  WudWerkr [ Thu Feb 06, 2014 5:16 pm ]
Alex
When I realized the whole situation , I kinda felt like the " Loose Nut" duh
Author:  WudWerkr [ Mon Feb 10, 2014 9:20 am ]
http://www.facebook.com/photo.php?v=422 ... =2&theater
Repair done , Another satisfied customer [:Y:]
Author:  brazil66 [ Tue Feb 11, 2014 8:51 am ]
Post subject:  Re: Gibson J35 Update Sound Link
It's great he brought it to you. Well done Wud.!
