https://www.luthiersforum.com/forum/
Who has made...?
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=42343
Author:  theguitarwhisperer [ Mon Dec 30, 2013 2:07 am ]
Post subject:  Who has made...?
......Steel String guitar necks out of Spanish Cedar?
Has it been a problem?
What have your experiences been?
Author:  the Padma [ Mon Dec 30, 2013 2:25 am ]
Post subject:  Re: Who has made...?
For Steel String guitar necks out of Spanish Cedar you need forum # USB7249-0045-234-1b & c,
filled out in triplicate, notarized and submitted 3 years in prior to commencing construction to the office of duh ?adma C/O dis here web site. Be sure to enclose the $125.00 payment for processing, along with the $200.00 filing fee and three pieces of id.
Author:  Jeff Highland [ Mon Dec 30, 2013 3:50 am ]
CF Martin that is
Author:  Clay S. [ Mon Dec 30, 2013 8:32 am ]
I have made steel string necks from Spanish cedar. They are a bit more bendy than mahogany necks so make sure you have a good truss rod.
Spanish cedar varies quite a lot in weight and stiffness, so you must judge for yourself if the piece has the qualities you require.
I know C.F.Martin used cedar for their early guitars which were primarily gut strung instruments, but have they used it recently, and for steel strings?
Author:  Quine [ Mon Dec 30, 2013 11:02 am ]
Works fine for a neck. Its a bit softer than regular mahogany so it might not wear as well if you're rough with it.....dents and dings will form if you bump a table edge something
Author:  grumpy [ Tue Dec 31, 2013 10:25 am ]
I've used it a lot(though it makes me sneeze and itch...). Martin is using it often these days, along with other 'mahogany-like' neck woods under the terms "select hardwood".
It makes a perfectly fine neck for steel string guitars...
Author:  Pmaj7 [ Tue Dec 31, 2013 11:32 am ]
I just noticed that one vendor was selling neck blanks of Spanish cedar, " the kind that doesn't ooz sap". Is anyone familiar with the different kinds of Spanish cedar?
Author:  Paul Eisen [ Wed Jan 01, 2014 8:23 pm ]
I used it on a couple of steel strings. I laminated oak in the middle to stiffen it up. Easy to carve and work, and with the center oak lam, it is holding up just fine.
But I hate the smell. It gets in my nose and stays there to party.
--Paul
Author:  theguitarwhisperer [ Wed Jan 01, 2014 10:00 pm ]
Thanks guys!
Author:  emoney [ Wed Jan 01, 2014 10:43 pm ]
I think Doug Kauer makes a lot of his electrics with Spanish Cedar bodies & necks. Carve away!
Author:  John Arnold [ Fri Jan 03, 2014 1:49 am ]
I think it is just a characteristic of the individual tree, rather than a separate species.
About 20 years ago I bought a whole pile of 8/4 SC from a sign maker, and some of it 'oozes', but most of it doesn't. In 1995 I made a two-piece steel string 14-fret neck out of it, and it did warp after about 12 years. The guitar obviously had been overheated at some time, since the bridge had lifted, leaving telltale strings of Titebond glue underneath. The heat also caused some 'bubbling' of the lacquer on the pores of the neck, but light sanding and overspraying a couple of lacquer coats made it like new.
I removed the CF fixed reinforcement, and installed an aluminum channel one-way adjustable truss rod. Problem solved. The current owner will undoubtedly take better care of the guitar, since he thinks it is the best thing since sliced bread.
Author:  Joe Beaver [ Sun Jan 05, 2014 6:15 pm ]
I too like sliced bread, but you need to give it a few extra minutes in the toaster if you want to have any chance of bringing it up to pitch. Like most things I learned this the hard way.
