https://www.luthiersforum.com/forum/
Devilbiss regulator issue
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=42164
Author:  James Orr [ Wed Dec 11, 2013 6:17 pm ]
Post subject:  Devilbiss regulator issue
I'm using a Devilbiss air pressure regulator right at the inlet of my HVLP gun. Fairly standard practice. It works fine most of the time, but won't work from time to time.
I sprayed two coats this morning and adjusted the pressure before each without issue. When I came out to do the third, the regulator's readout was jacked up to 160, but hardly put out any air. Dialing it down sent the read-out to zero immediately, dialing it up added about 5psi to the read-out, but nothing higher.
Does anyone know what might be going on? Pressure coming out of the compressor itself was fine.
Author:  Goodin [ Wed Dec 11, 2013 7:01 pm ]
Post subject:  Re: Devilbiss regulator issue
Did you check the air knob on your gun?
Author:  James Orr [ Wed Dec 11, 2013 7:46 pm ]
Yep. I always leave it fully open.
Author:  James Orr [ Thu Dec 12, 2013 12:44 am ]
I'm going to get a replacement. I took it out of the line and adjusted the pressure at the gun. Everything was fine.
