It is currently Wed Aug 20, 2025 9:27 am
PostPosted: Wed Dec 11, 2013 6:17 pm
I'm using a Devilbiss air pressure regulator right at the inlet of my HVLP gun. Fairly standard practice. It works fine most of the time, but won't work from time to time.
I sprayed two coats this morning and adjusted the pressure before each without issue. When I came out to do the third, the regulator's readout was jacked up to 160, but hardly put out any air. Dialing it down sent the read-out to zero immediately, dialing it up added about 5psi to the read-out, but nothing higher.
Does anyone know what might be going on? Pressure coming out of the compressor itself was fine.
PostPosted: Wed Dec 11, 2013 7:01 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Did you check the air knob on your gun?
PostPosted: Wed Dec 11, 2013 7:46 pm
Yep. I always leave it fully open.
PostPosted: Thu Dec 12, 2013 12:44 am
I'm going to get a replacement. I took it out of the line and adjusted the pressure at the gun. Everything was fine.
Users browsing this forum: Bing [Bot] and 21 guests
